WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side Clean your computer of dust using a can of compressed air or a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit. If you use a vacuum cleaner dont use one with a metal pipe if it touches anything on your motherboard it might short something out. hope this helps
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
dust causes static to build up in a computer
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
dust causes static to build up in a computer which can affect all of your computer
hope this helps
