Question about Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot C330
Unit can no longer acquire satellite signal. The map shown is the map of the last location I traveled to. Unit continually displays "Aquiring satellite signal", then prompts "Are you indoors?".
I have the same problem. called garmin and they said the internal battery needs to be replaced. of course that can only be done by shipping it back to them. i just leave mines plugged into my lighter so i dont have to turn it off only to have to wait soooooo long when i turn it back on to pick up the sats. oh, i also hide it in my console so no one can see it shining in my car overnight. hope this helps.
Posted on Nov 22, 2008
  • 3 Answers
This seems to be a common problem and my unit has the same issue. Hopefully someone from Garmen monitors this forum and will offer a suggestion or explaination. Perhaps leaving the units in a hot car in the summer fries something that affects sensitivity of the unit.
Posted on Nov 20, 2008
How to update maps on a garmin street pilot c330
Please join everyone else in the 21st century and buy a unit that does not look like a CRT tv.
Aug 21, 2014 | Garmin StreetPilot C330 GPS Receiver
My garmin street pilot c330 won't aquire satillite. this unit is 2 years old, but never out of the box. i got it from my son and tried to set up. when you turn it on all of the data in the unit is...
Try connecting in your car and leave it on and let it charge while you are driving it may eventually find the satellite, it probably remembers the last satellite it found which was in Kansas. You may not be getting a signal where your are right now so run some errands and leave it connected in your car.
You can also go to the garmin web site and try updating the unit. You will need a usb cable and will need to install garmin updater. Make sure the unit is fully charged.
If this does not work you can call garmin and they are usually very helpful. Here is the garmin link which will help answer some more questions.
http://www.garmin.com/garmin/cms/site/us/support/
Let me know what solved the problem. thanks for using fixya
May 14, 2011 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 says trouble tracking satelites, not acquiring signal. what to do?
If your StreetPilot c300 or c500 series device is no longer acquiring satellites please read the article linked below to ensure that this is not being caused by something in your environment:
Why won't my unit acquire satellites?
If after reading the above article your unit is still having problems, please ensure that your unit's software is up to date. You can do this by using our WebUpdater® program.
If you have tried all of the above suggestions and your unit is still not acquiring satellites, you can perform a master reset by doing the following:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit powered OFF and unplugged from power.
  2. Touch and hold the bottom right corner of the touchscreen.
  3. Power the unit ON and continue pressing the screen until a new message displays, "Do You Really Want To Erase All User Data?".
  4. Touch Yes and go through the set up again.
Take the unit outside and let it set with a clear view of the sky for 3-5 minutes to acquire satellites. If the unit still does not acquire satellites after this, please contact Garmin Product Support.
Nov 17, 2010 | Garmin StreetPilot C330 GPS Receiver
My Garmin c330 has difficulty acquiring satellites in my new 2009 Camry XLE. Does it have something to do with Bluetooth? Does it interfere? Ever since we bought the 2009 Camry XLE in June, the Street...
The C330 does not have bluetooth capability. Regardless, this has nothing to do with the unit's ability to acquire satellites. Nor should the type of vehicle you purchased, unless the unit is unable to receive due to some feature, like something in the windshield, which is preventing the unit from receiving a proper signal. Does the unit work outside the vehicle?
Aug 02, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot c330
Have you tried resetting the unit?
Jul 10, 2008 | Garmin StreetPilot C330 GPS Receiver
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Street Pilot problem
Having the same problem. Worked great for a year, and then couldn't connect once, and now never connects. I can never find any satellite and as such is pretty worthless.
Mar 21, 2008 | Garmin StreetPilot C330 GPS Receiver
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Cracked screen on Garmin street pilot 330
Given the cost of buying a new LCD with touchscreen is about $130 USD + shipping. Your best solution is to sell the existing unit and buy a new Nuvi or recondition C330.
Garmin will repair the unit for $150 and provide the lastest update and map.
Jan 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
80 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
