Question about Coleman 2 Burner Dual Fuel 424-700G Grill
My 424 has no presure at jet end, yet when pumped feels solid?
Have many colemans so am not a complete geek! tis as if unit is alredy up to full presure(and abit more! ) when fuel cap released no presure is found? had pump assy apart no faults found? generator is all ok? possible blockage in tank,blown through with compressed air,still no good? thanking you in advance, mark tanner.
Gave valve in lower pump assy a good poke all now ok!
Posted on Nov 18, 2008
I have a everbilt 1 hp shallow deep well jet pump. It does not have good pressure. I was unable to put the extended plastic jet adaptor in the pump. I could not install it
you can adjust the pump switch to get higher presure its the box on the outside of the pump with two screws, one is an upper limit screw to turn the pump off at the proper presure ,the other screw turns the pump on when it gets to a low presure,Make sure electric to pump is off.
Jun 11, 2017 | Plumbing
Coleman 424 duel fuel stove leaking fuel at control knob. Took that whole section apart today and it seems there is some sort of dark grey hard putty like gasket material in the joint there and I guess it...
A complete new valve assembly isn't very expensive and you can often get one on eBay with a new generator included. It's not worth servicing the old valve given the safety implications of leaking fuel.
Aug 12, 2013 | Coleman 2 Burner Dual Fuel 424-700G Grill
Hi my coleman 533 has orange flame not blue it has good pressure i have taken jet of end of generator and cleaned it
Orange or yellow flame is usually an indication of too much fuel, or not enough air mixture. Make sure all areas where burners would receive air from, are cleaned of spider webs, debris etc., and be sure when set up, nothing is close to it that would block that air flow from entering.
May 27, 2011 | Coleman 2 Burner Dual Fuel 424-700G Grill
The canister doesn't seem to be pressurizing after pumping steadily for 1 minute
on some models you need to rotate the plunger to engage the seal then pump it.
Aug 29, 2010 | Coleman 2 Burner Dual Fuel 424-700G Grill
My coleman 424 stove has been sitting in shed for a coulpe of years, now got it out again. Filled with petrol when pumped up I can light it but flame only lasts a few minutes then it dies as if no...
My best answer is that your pump seals have dried out and are allowing pumped up pressure to leak back past the pump seal
Pump it up hard then quickly attach a small balloon with a rubber band around the base of the pump - where it contacts the tank. A deflated balloon or a small plastic baggie - does the balloon begin to fill with air after a few minutes - if yes then your seal is leaking.
You might try taking the pump apart and soaking the seal overnight in fuel reinstall and see if it cores your problem
Good Luck
Mar 22, 2010 | Coleman 2 Burner Dual Fuel 424-700G Grill
Water won't empty. the bottom remains full
check to see if the water is draining completely. let it fill then drain and cancel unit check to see if this works if not check the drain pump. might also you will want to check soap,alot of times you can add jet dry and lets say a cascade with jet dry shine sometimes can over suds a machine this will cause the unit to keep rinsing to get the soap out,so when it finally ends there is extra water in unit. it is called over sudzing. let me know if my tip helped you.
Feb 23, 2010 | Dishwashers
Coleman 424 Dual Fuel -- High, yellow flame
Are you pumping the tank up all the way? I have the same problem if I have too little pressure in the tank. The instructions say pump 35 times. Try pumping 50 or 60 times- that seems to help.
Also, you can't light this one like an old 425. My old stove you could turn the gas on and then take a match neat the burner. For this stove, hold the match near the burner with the gas off and quickly turn it on.
These are two things that seemed to help me with the same problem.
Jul 11, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman 424-700G Burner/Pressure Issue
I had a similar problem today, After taking the ump assembly to pieces i disovered that the pump"stem" needed turning slighty anti clckwise to allo tepresure to build up inthe tank. I felt very stupid buta big learning curve for me.
Sep 28, 2008 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman 2 Burner Dual Fuel 424-700G Grill Logo
275 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
