That is an odd problem, however, I would not recommend you disassemble your laptop unless you are either mechanically inclined, can afford to damage it beyond repair or have previous laptop disassembly experience.
Having said that I would check the following before taking anything apart:
-Is it getting power; a quick check is to see if your battery is fully charged.
-If you are starting your laptop cold (its been off for at least an hour) overheating probably isn?t a factor unless something catastrophic is wrong. Cleaning probably won?t accomplish anything.
-Open the memory compartment, remove and reseat the module. I?ve had several cases where this has worked loose.
- Have you recently replaced or added hardware to your laptop or upgraded firmware? If you have and you can undo safely try that next.
If that all fails I would suggest that this is probably a repair best left to the local authorized Compaq repair shop. Failure to boot without any type of error messages being displayed are usually fairly serious and requires repair parts and diagnostic equipment.
Comments:
Dec 03, 2006
- I agree, recycling like that for me has usually been a faulty processor (power surge or massive overheating), an overheating processor (faulty CPU fan or system, excessive dust), or another failed component. I recently had a Dell desktop display the same symptoms due to defective capacitors on the main board.
Anyway if you?re starting the laptop cold it is unlikely it could overheat that fast unless something major is wrong like a power short; that you would probably smell as well. So your fault is likly with a component on the main board.
Most if not all laptop CPUs are not socketed these days. Too many reliability issues with thermal expansion and rough handling thus they are soldered onto the carrier board. Again I wouldn't try to replace a laptop processor or other integrated circuit unless you have the specialized equipment, skills and experience required to properly remove and reattach LCC devices. If you go this route you'll likely create other problems on your main boards which will make it that much more expensive to repair.
