Question about Honeywell Programmable Thermostat Heater
Thermostat not working
Keep trying to raise the temperature from 63 degrees to 71 and it will not work
  • cnprimo Nov 20, 2008
    My thermostats, model RTH6300B which were installed about 10 mo ago, have not been triggering the heat the last two nights, but randomly kicked in about 1.5 hours after the scheduled time in the morning. The pilot light is on on the furnace & when I tried to raise the heat later in the day the system responded appropriately. Any thoughts???
  • rselsing Dec 07, 2008
    I have a RTH2310 programmable. It doesn't match the actual room temp and won't switch the temp down at night. Right now it is set at 71 degrees and the room is actually 66. The thermometer is in same location as the thermostat.
  • 34 Answers
What thermostat is it, and is the furnace on?
Posted on Nov 17, 2008
Fridge keeps freezing
Cold air falls so unless your fridge has a fan the bottom is always going to be colder than the top. Raise the temperature by a couple of degrees, as your thermostat is reading the temperature at the top.
May 29, 2015 | Refrigerators
Heat pump not keeping up to set temperature on thermostat but never drops below 63 degrees whens its 20 degrees outside.
It may be getting low on refrigerant due to a small leak. I'd have it serviced soon. When running at less than peak efficiency it will much more often switch on the heat strips and they are not cheap to operate.
Jan 06, 2015 | Heating & Cooling
How do i adjust AC temperature variance on a Honeywell TH5220D1003 thermostat
If you are talking about the difference between heating mode and cooling mode and the room setpoint, you can not change it. It comes from the factory with a 3 degree difference. In other words if you raise the heat setpoint until it is within 3 degrees of the cooling setpoint, for every degree you raise the heat setpoint the cooling will raise a degree.
About all you can do is increase the distance between the heat and cooling setpoint. To do this either lower the cooling setpoint to 3 degrees higher than the heat setpoint you want and then increase the cooling setpoint the desired setting. For example heat and cool setpoints are 67 and 70 respectively, and you want 65 and 73. Lower the cooling setpoint to 68 and then raise the cooling setpoint to 73. Now your heating will come on 3 degress lower than 68, the 65 you wanted and cooling will come on at 73. Remember, the thermostat new setpoints will turn on the cooling at 75 and turn back off at 73 and heat will turn on at 63 and turn off at 65.
You can perform the same using the heating setpoint, just have to look at it backwards. If you need to lower the difference I recommend a 8000 series thermostat. They are the most functional thermostat that Honeywell makes, be in mind they are about 3 times more expensive and many of the setting require a well trained tech to interpret and set properly.
Hope this helps.
Aug 24, 2014 | Honeywell Th5220d1003 Non-programmable...
Ritetemp 8022c
After you program the thermostat..the temperature numbers stays on the screen a few seconds then starts to indicate the temperature of the room. This is normal.
Nov 29, 2013 | Heating & Cooling
Goodman GKS9. I have this unit in a condo that I only use sparingly in the winter. I keep the dual thermostats both at 57 and it maintains that tempeature. The problem is that when the thermostat is raised...
The presure switch is breaking down try taking the tubes off and blowing down the switch , or take a small drill bit and clean inside the connections to the pressure switch some times this becomes blocked .
Jan 16, 2012 | Goodman Heating & Cooling
Whdoes it mean of wake, return, sleep and leave on honeywell digital thermostat
I believe it means (I assume winter weather in my example):
1. Wake - This is the time you wake up and you would set the temperature at the time you want it then. So, your temperature throughout the night might have been set at 63, and if your "wake" time on the thermostat is set to 6:00 am and 68 degrees, then your system will automatically adjust the temperature setting to 68 degrees at 6:00 am.
2. Leave - This is the time that you would typically leave your house for work. You probably don't need to heat or cool your house that much during this time especially if no one will be there. So, let's say you leave for work at 8:00 am. You would set this time for 8:00 am and 60 degrees.
3. Return - This is the time you get off work. Let's say you get off at 5:00 pm. You would set this time for 5:00 pm and 65 degrees. Then the system will start warming up at 5:00 pm and will be warmer by the time you get home.
4 - Sleep - This is for when you go to bed. Following the example, let's say that you set your temperature while sleeping to 63 degrees at 10:00 pm. Then, the system adjusts at that time and will adjust again as soon as then next parameter is met, which at this point would be the wake time.
This is usually for a Mon - Fri schedule and then a separate one for the weekend.
Jan 02, 2012 | Honeywell Programmable Thermostat Heater
I have my Emerson FR966T wine coller set for 60 degrees, but my cooler never seems to get the high. It always hovers around 58-59. When I heat my house up (never above 68) my cooler seems to warm up to...
Yes, because the fridge is a heat exchanger. The trade off for cooling the inside is a condenser coil on the outside which is warm. If you raise the temperature on the outside it will affect the inside a little. Having said that, the thermostat should keep the temperature within specifications. If you have it set for 60 and it is 58 or 59, to me it is within spec.The difference in 2 or 3 degrees Fahrenheit is tiny.
Also it should be pointed out this is a $63 cooler from Walmart. If you want a good one for storing thousand dollar bottles of Chateau Margeaux, you need a $600 wine cooler with a solid state digital thermostat and controls that talks to your smartphone when the temperature is one degree off..
Oct 21, 2017 | Refrigerators
Does the T8602C1095 have an anticipator that may need adjustment when the temperature set is exceeded, eg we set at 70 and it goes to 71-72 and then need to manually shut down system.
that is how they work. ther is a 1 to 3 degree variance up or down.it probaly does not kick back until 67 or68 degrees. a two stage furnace will keep a more steady temp.
Oct 01, 2009 | Honeywell Electronic Programmable...
First floor of house is cold
The thermostat will turn your furnace on and off to satisfy the temperature setting at the location where the thermostat is located. If you move the thermostat to the first floor and set the thermostat at say seventy, it should keep the furnace on until the temperature near the thermostat hits seventy degrees.
Feb 06, 2009 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
89 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
