Question about Honeywell Consumer Products Mechanical Heat/Cool Thermostat Heater
Honeywell Old T874D1512 dual heat/cool thermostat
Dual heat/cooling mercury-2 controls with an automatic setting on each side--when I set the heat to come on the unit will not react--I can set the heat control to ON and the unit will run warming slightly--the unit will not turn on when it is set to automatic it shuts off--
I do not know what the 2 half moon dials under the thermo cover are for and how to set them properly - this is a commercial large unit. It is in the factory area. Thru the years the thermostat cover has been removed and I feel these small dials have been tampered with--
Is it possible to explain to me the purpose of the dials? I know this is an old thermostat but I really need to work with what I have--times are ruff and I really don't have the money to replace the thermostat if it is something I can adjust. Of course, I donot have the paperwork that came with the unit or the thermostat. I also donot have the knowledge to replace the thermostat. It cycles on and off OK through out the day once I get it on. I've done so many different things I'm not for sure what has worked. This thermostat had 1 control for the heat and 1 control for the cool. On the left side on the bottton of the unit is Auto---On The right side is Off Heat Auto Cool
I set it to Auto and Heat and put the top gage to 80 degrees and the unit will not turn on--after setting it to On and let it run for a while, sometime I can slide it to Auto and it will stay on but usually it turns off. After leaving it on On for 20+ mins it may stay on when I slide to Auto
I hope I'm making sense. I really think it may have to do with the moon shaped dials. I do not know what their purpose is. I have looked for information on these dials on the site but everything has gone to programmed thermostats. I figure my employees could really screw one of them up. Should I try to dust the coiled wire as in all factory
there is some dust inside the cover.
If I haven't given you enough information just let me know. You need to keep you information to me in "woman's terms" if possible. I pretty handy with things or I think I am.
But some of the termonology may be greek. Help me work with this unit and not replace it yet.
  • 308 Answers
I think I understand what you are saying....First, that switch marked On and Auto, is to control the blower fan only. So when you switch that to On, it turns on the blower, but not the actual heat. It sounds more like a problem at the furnace then at the thermostat.
Posted on Jul 20, 2009
Bryant/Carrier Roof mount heat pump 664ANX042000AAAF wiring diagram and capacitor help. Which capacitor is for inside blower motor?
typically a cap for a blower motor is a single purpose capacitor where as the condenser side would be a dual purpose capacitor. 3 sets of plugs for dual, 2 sets of plugs for a single. Hope this helps.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 08, 2018 | Heating & Cooling
I have a nordyne dual unit e2eh012ha and the blower won’t come on in auto when calling for cooling. It will work if the fan switch is set to on but then the A coils freeze. The previous owners did not...
the blower runs when in on position but the coil still freezes?? that may be a separate issue but it sounds to me like a setting issue in the tstat. you need to read the manual and set the setting to where the tstat controls the fan rather than the equipment controls the fan.
Apr 26, 2018 | Heating & Cooling
I want to hook up a new Honeywell thermostat that has 8 wires in place of an old mercury one that had 5 wires
You just need to used that 5 wires. The rest you leave blank. Your new thermostat has stage 2 heat and cooling also 1 for reversing valve which you don't need.
Jan 06, 2018 | Honeywell Heating & Cooling
2006 mercury mountaineer when heat is on it blow hot on driver side and cold on passenger side.
There are dual blend doors in the heater blower unit, one for the passenger side is not working. Could be loose, jammed or broken.
Feb 05, 2017 | 2006 Mercury Mountaineer
I have a Honeywell RTH6580WF Wi-Fi Thermostat that has "Cool On" or "Heat On" flashing in an endless loop. Could there be a major issue?
Pull the power red wire off the thermostat and batteries out if it has battery backup, then reinstall...much like a computer restart. If this doesn't work, then replace your thermostat.
Jan 21, 2016 | Honeywell RTH6580WF Wi-Fi Thermostat
In the cooling mode for zone 1, why won't the temperature stay as set on the cool setting?
If it 2 degree cooler then that's fine .adjust your thermostat 2 degrees higher so you will get the temperature
Feb 16, 2018 | Carrier Heating & Cooling
FocusPro TH5000 will not cool
Make sure the thermostat is set to "cool" mode. Make sure the thermostat is wired correctly and has fresh batteries in it. Check both the thermostat end and the air handler end of the wires. If All this checks out, the problem is most likely in the air conditioner, not the thermostat.
Mar 29, 2014 | Honeywell TH5220D1003 FocusPRO 5000...
Armstrong Concept 12 heat pump blows warm air when the thermostat is set on cool
likely in the configuration need to change when the reversing valve is energized. sometimes energized when in cooling ,sometimes when in heating. whatever yours is on its likely the opposite.
Nov 12, 2017 | Heating & Cooling
Can i install a time temp. type defrost control instead of the demand defrost type in the above unit? also i see no reason for the fan control board (low to High speed) since the fan motor does not call...
Defrost timer might be more reliable here in NY I set them @ 45minutes..The fan speed is out side tempature (ambient) selected ,low speed, running when its cooler out but you still use cooling.HIGH speed being the default speed.High/low during spring and low all winter.If your new motor is only one speed power it direct from the contactor
Jun 07, 2011 | Heating & Cooling
I have a two wire thermostat system. I switched the thermostat from a mercury one to the Honeywell CT3200 with dip switches set for my electric forced air furnace that is 31 years old. The white wire is...
If you look closely at the installation manual page 6&7 it tells you settings to use for your type of system. If I'm not mistaken you will need to back out screw "b" 360°. Hope this helps!
Jun 17, 2017 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
167 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
