Question about Cyberhome CH-DVD 300 DVD Player
I dint find the P.Scan button??I went into options n changed something.I have no vidoe ouput,only audio
  • 80 Answers
Dear friend,
press and hold the stop button of the dvd player front panel.more than 5 sec. the player will be reset. and clear the problem
Posted on Nov 20, 2008
No audio output device installed
Under sounds no audio is installed, scan for hardware changes, still no luck try this: Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally. Check device manager for audio, scan for hardware changes. reconnect to tv.
Nov 06, 2012 | Computers & Internet
It shows a no audio ouput device is installed in the lower right area. I have tried scan for hardware changes and it still doesnt work. is there a way i can just download a new audio output device?
Try this,
1 Go to Device manager and look for sound and expand it. 2. Unable to find Device manager ?? Then Go to Start button, click Control Panel, click System and Maintenance, and then click Device Manager.?If you are prompted for an administrator password or confirmation, type the password or provide confirmation. 3.Make sure you don't have a symbol "!" on the Default Audio Driver. 4.If you do/don't just right click on it and go to properties and click on upgrade.
Another solution could be if you click on your sound icon at the bottom right and expand it. You might have one out of x many different sound mixer muted. Unmute them all.
If this helpful, please give a testimonial and vote by pressing button thumbs up.
Sincerely, Thiyaga
Aug 27, 2011 | Computers & Internet
I have a LG HDD DVD recorder which was given to me without any instructions. How do I plug it into the LG sound system and then the TV? I have 2 yellow white red leads and 1 red and white lead.
the red led i thingk is for recording,, light is power on,,, used rca audio output to connect to your lg.... or digital optic ouput... vidoe out to your tv video in
May 30, 2011 | LG RH177 DVD Recorder/HDD Recorder
I have just moved from australia to the uk and need to change the setup for my pinnacle tv stick, ne ideas, dint think it would be difficult at all, but cant find option for changing country for channel...
First, get the installation CD. If not having, then download one or buy from vendor. Now uninstall the existing software. Reboot ur computer. Then reinstall. There u will find all options.
Sep 04, 2009 | Pinnacle PCTV HD Pro Stick USB 2.0 TV...
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
No audio on some hd channes
Try pressing the MTS button on your remote while on the channel that does not have audio and select stereo. Most likely this will be set to SAP (secondary audio programming) and there is no SAP programming on that show. This is not something that could be avoided. It was during the channel scan, it locked in the SAP audio broadcasts for some reason.
Apr 03, 2009 | Vizio VW42LF 42 in. LCD HDTV
Vido player
You have to download video and audio codecs for that matter. Go to this link:
Download it. When a box appears, Click Run button.
*Delete all your temporary internet files. Drop me a comment and i will assist you. Your vote will be appreciated. Thanks in advance.
Best regards
Jan 14, 2009 | Dell Wireless 5530 Mobile Broadband...
Web cam
you probably need to change the out put of audio
found somewher in options with your video
Dec 02, 2008 | Toshiba Satellite A205-S4617 Notebook
Audio problem
In your set's menu you should have an option to turn off/on the internal speakers,If you bring the menu up on the screen you should see options to change the video settings like color,brightness but also ther should be an option for audio witch include balance, treble, that screen you should see the option that says speakers try switching between on or off.Please let Us know how it goes or if you need more information.
Oct 10, 2006 | Sony FD Trinitron KD-36XS955 36" TV
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
