Televison & Video Logo
Anonymous Posted on Apr 27, 2012
My tvfisher-Mod PR3527 turn on and after 5 second turn off?
Wnen I turn on, five second after was one off
Level 3:
Top Expert:
  • Fisher Master 76,851 Answers
  • Posted on Apr 28, 2012
Fisher Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994890
Points
237762
There might be some shorted component/s on the circuit board inside. Your TV need service.
2006 ford five hundred headlights brighten every 5 seconds
Sound like a bad ground somewhere but it is strange its every five seconds. See if you can hear a relay clicking somewhere under the hood or dash.
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
How to reset anti theft system
KEYLESS ENTRY SYSTEM You can use the keyless entry keypad to:• lock or unlock the doors without using a key.• open the trunk.• recall memory seat/mirrors/steering column/adjustable pedals positions1 or 2. The keypad can be operated with the factory set 5-digit entry code; this code is located on the owner's wallet card in the glove box, is marked on the computer module, and is available from your authorized dealer. You can also create your own 5-digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation. Programming a personal entry code. To create your own personal entry code: 1. Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. Note: The lock motors will cycle, locked then unlocked 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other. 4. Enter a sixth digit to indicate which personality feature should be recalled by the personal code. Note: The lock motors will cycle, locked then unlocked. • 1 • 2 recalls driver personality 1. • 3 • 4 recalls driver personality 2. • 9 • 0 does not recall a driver personality. Wait 5 seconds without pressing a keypad button in order to store a personal entry code. Tips: • Do not set a code that uses five of the same number. • Do not use five numbers in sequential order. • The factory set code will work even if you have set your own personal code. • If you set a personal code and store it over an existing personal code it will erase that personal code only. Erasing personal code 1. Enter the factory set 5-digit code. 2. Press and hold the 1 • 2 for two seconds and release; this must be done within five seconds of completing step 1. 3. Press and hold the 1 • 2 for two seconds to erase the customer programmed code; this must be done within five seconds of completing step 2. Your personal code is now erased and only the factory set 5-digit code will work.
2answers
I have a domotherm OT thermometer and need to know how to change it from freinhieght to celcius
Press start for 5 sec. the display Cor F will flash, release start and press again to toggle between C OR F, leave for five seconds for display to settle. Have fun.
I HAVE A RCA REMOTE RCR412S THAT REQUIRES 5 DIGIT CODES AND HAS NO LISTING FOR AN ORION VCR. PREVIOUS REMOTE A RCR812 HAS A 4 DIGIT CODE AND OPERATES THE VCR.WHAT WOULD BE A 5 DIGIT CODE FOR THE RCR412S?
the Automatic Search method worked because the manual was incorrect. Here is how to program the RCR412S using the Automatic Search method:
1) Turn on the component you want to control (TV, VCR, DVD)
2) Press and hold BOTH the component button on the remote and the On-Off button
3) The On-Off button remains lit. Now press Play (The On-Off button will blink)
4) If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
5) When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
6) To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
I hope everyone finds this helpful and that it saves people time and frustration.
1helpful
How do I change the code for key less entery on the key pad on door
Programming a personal entry code The factory set code cannot be reprogrammed but you can create your own 5 digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation.
Up to three personal entry codes may be programmed to the vehicle. To create your own personal entry code:
  • 1. Enter the factory set code.
  • 2. Within five seconds press the 1-2 on the keypad.
  • 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
  • 4. Press 1-2, 3-4 or 5-6 to indicate which of the three personal entry code positions you wish to use.
  • 5. The doors will again lock then unlock to confirm that your personal key code has been programmed to the module.
Tips:
  • If you program a code to a position that already contains a set code, the previously-set code will be erased.
  • 1. Enter the factory set 5 digit code.
  • 2. Within five seconds, press the 1-2 on the keypad and release.
  • 3. Press and hold the 1- 2 for two seconds. This must be done within five seconds of completing Step 2.
All personal codes are now erased and only the factory set 5 digit code will work.
Good luck (remember commend and rated this).
Loud squeaking wnen turning and moving. in the
worn rubber suspension bushings and dry steering tie rod ends cause this, have a tire shop do a courtesy inspection, it is free at most.
3helpful
HOW DO I RESET MY DOOR CODES FOR MY 1996 GRAND MARQUIS
  • 2. Within five seconds press the 1 � 2 on the keypad.
  • 4. Press 1 � 2, 3 � 4 or 5 � 6 to indicate which of the three personal entry code positions you wish to use.
Tips:
  • 1. Enter the factory set 5�digit code.
  • 2. Within five seconds, press the 1 � 2 on the keypad and release.
  • 3. Press and hold the 1 � 2 for two seconds. This must be done within five seconds of completing Step 2.
All personal codes are now erased and only the factory set 5�digit code will work.
2helpful
Keypad door lock does not work..?
it's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
Keyless Entry Keypad To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
  • Enter the permanent factory code.
  • Enter the owner's alternate code.
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment. To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s). To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) . To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.) This will turn off courtesy lamps and arm anti-theft alarm control (if equipped). To program an alternate code:
  1. Enter the five digit permanent entry code into keyless entry keypad .
  1. Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
  1. Enter any alternate five digit code within five seconds of pressing 1/2 button.
    • Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
      • 9/0 — no memory recall
      • 1/2 — memory seat position 1
      • 3/4 — memory seat position 2
      • 5/6 — memory seat position 3
    • After successful programming, the doors will signal by locking and then unlocking.
  • Keyless Entry Keypad Does Not Work Properly
  • Circuit.
  • Keyless entry keypad.
  • Electronic door lock control processor.
  • Open Fuses:
    • Town Car and Crown Victoria/Grand Marquis
    • Power Distribution Box (under hood)- K, 40A (Maxi)
    • Instrument Panel Fuse Panel - 17 (10A), 10 (20A), 8 (15A), 5 (15A) and 4 (10A)
  • Loose Connectors
  • Corroded Connectors
  • 5helpful
    2answers
    Have a series of 5 chimes 5 times believe its
    The secondary air bag warning is an audible fault format that consists of five sets of five tone bursts, with each set of five tone bursts separated by a five second quiet period. One tone burst cycle will consist of one second ON and one second OFF. This series of five activations is repeated every 30 minutes.
    This will tone if the air bag indicator is inoperative.
    Suggest to have the dealer or someone with a scan tool that will communicate with the restraint system retrieve codes.
    Top Fisher Televison & Video Experts
    matt martin
    matt martin
     Grubhead
    Grubhead
    Are you a Fisher Televison and Video Expert? Answer questions, earn points and help others
