Question about RCA F27442 27" TV
Rca f27442 My television has no picture or sound. It makes a whining sound that won't stop until the tv is unplugged. When I plug it back in, the whine starts again. I left the tv on one night and woke up with the noise and no picture. It hasn't worked since.
    Sergeant:
  • 308 Answers
You may be able to get by with just a new Horizontal output Transistor location Q14401 after repairing the coil L14401 connection. I suspect the repair would not be worthwhile if the high voltage (flyback) transformer is bad as well as that part costs about $50.00 by itself.
Posted on Dec 24, 2006
  • 7 Answers
Check for shorted base-collector junction on horizontal output transistor designator Q14401. Also coil L14401 going to base of transistor needs to be desoldered, scrape ends, resoldered. If horizontal transistor is shorted, real possible flyback transformer bad.
Posted on Dec 22, 2006
SOURCE:
No picture but have sound. RCA Model F27442
you have the problem in the heater try to resolder the parts in the crt socket the one that is connected in your picture tube if nothing happens check the resistor if open replace it common value is 5.6ohms.
Oct 14, 2010 | RCA F27442 27" TV
No picture but has sound
Coil L14401 is not making a good ground. Remove him carefully, scrape the ends clean and the board where he was removed. Now reinsert and resolder this little guy,and Bingo you have your TV back. This is a common problem with your TV! Thanks for asking!
Jan 30, 2010 | RCA F27442 27" TV
My RCA F27442 dosen't any picture put it dose have sound what can i do
Coil L14401 needs removed and the ends scraped clean. Clean the board where the coil was removed and reinsert this coil and resolder. Your TV will be back as as good as new! This coil is located near the Horizontal Output transistor!
Dec 05, 2009 | RCA F27442 27" TV
I have a rca f27442 tv and the picture is half
yes!!!! very common problem. soldering the vertical section and the grounds around the tuner section will fix it. guaranteed fix. for a quick fix, take off back and while tv is on, take the plastic side of screwdriver and tap tap tap the tuner section. see i told you that would fix it.
Nov 10, 2009 | RCA F27442 27" TV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Guide plus rca tv how do stop it from coming up when turning on tv
I have a rca tv guide plus that has the back pannel lights on, but is unplugged, what is the problem?
Jan 04, 2008 | Televison & Video
RCA Model F27442 has sound but no picture
check to see if you have B+ to the horz.output transistor.
also you may have bad solder connections on the countdown osc. ceramic resonator.
Dec 24, 2007 | RCA F27442 27" TV
RCA F27442: no picture.
you may have bad solder connection in the horiz.countdown section.
you may also have a GEM Star module bad.
Nov 06, 2007 | RCA F27442 27" TV
RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Oct 13, 2007 | RCA 32F531T 32" TV
RCA F27442 27" TV Logo
123 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
