Question about HP PSC 2355 All-In-One InkJet Printer
IRON ON TRANSFERS
HIYA.. CAN ANYONE TELL ME IF HP C5280 CAN BE SET TO IRON ON TRANFERS IN THE PAPER TYPE WHEN COPYING... I WANT TO USE THIS AS A STAND ALONE ( IE NOT CONNECTED TO A PC)... AND I NEED THIS FEATURE... I CONTACTED HP BUT THEY COULDNT TELL ME... I DONT WANT TO SPEND MONEY ON A NEW PRINTER THAT CANT DO THIS.....THANKS
  • martin_lenno Nov 17, 2008
    thanks... i want to know if the c5280 has this option..
    thanks for replying so quickly...hp were a bit useless to be honest.... she couldnt understand i wasn't connecting it to a pc and kept telling me how to mirror image using software...
  • HP Master
  • 1,879 Answers
Iron-on paper size is A4. Use Plain Paper for the type.
Important: Image will end up backwards when ironed if the Photo Options screen does not have an option to FLIP the image.
Posted on Nov 17, 2008
  • monk3ybidzness
    monk3ybidzness Nov 17, 2008
    To be 100% sure (can't cope up with all models released in the market), give HP a quick call, you know exactly what feature you by now. Have the rep get the model and look for the option.
HP officejet pro 7680 print settings for iron on transfers
as a paper profile when loading use a paper that is nearest to the paper type being printed- EG- plastic sheets would become Vinyl paper/ transparency or banner profile.#
alternatively go to HP website and then to paper profiles and download the ICC profiles required follow the user manual to install to printer.
Jan 17, 2014 | HP OfficeJet Office Equipment & Supplies
I have an HPPhotosmart C5280. I want to print on an evelope 8.2 x 5.5 for a wedding invitation. The printer tells me paper mismatch every time I try it. I set it up every time on the computer, it prints...
The easiest way to print an envelope is to use Microsoft Word. If you have the software installed, go to start and then create new office document and click blank document. When the document opens, click on help and type in envelope. This will give you instructions on how to create an envelope and save a copy to your document. When you save a copy to your document, it gives you a picture of an envelope which helps to create it. Then click on file, and slide down the print and click ok. Creating the envelope through Word helps to change the printers paper settings. Word will send a signal to the printer to tell it what type of paper and size of envelope you are creating.
Hope this helps?
Jul 18, 2011 | HP Photosmart C5280 Printer
How do I get my C5280 Photosmart to accept 230 gsm card without jamming and then print without smudging? Am I using wrong settings?
If you printer support that specification of paper it will print on it. You have to select appropriate paper type from printer settings.
Nov 12, 2009 | HP Photosmart C5280 Printer
I was wondering if this printer can print on iron on transfer paper?
This is a direct quote from HP.
Media Types, "Paper (plain, inkjet, photo), envelopes, transparencies, labels, cards, HP's premium media, iron-on transfers, borderless media, panorama"
So to answer your question, it would be yes.
I hope this helps and good luck!
Nov 04, 2009 | HP Photosmart C5280 InkJet Printer
HP Photosmart C5280 doesn't print photo
my steven
u need to chek setting of pritner in pc when u do pritner command it's show pritner propaty this is capple of options like in cd pritner on photo 4x6 also give all setting u have to chek this setting it's help u
Jan 09, 2009 | HP Photosmart C5280 InkJet Printer
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
Iron on transfers lexmark x1290
In your printer driver, select the highest dpi setting and the correct paper setting for your type of printer:
Iron-ons are very waxy and the ink may not adhere if not put on thickly. Bellow are some suggested printer settings. For the best results check your printer manual or with your printer's manufacture. CANON: T-shirt transfers.
EPSON: High quality glossy paper or special coated paper, depending on the model.
HEWLETT-PACKARD: High quality glossy paper.
Lexmark: T-shirt transfers.
IMPORTANT: Then set the paper thickness lever on your printer for standard paper. You want the ink nozzles very close to the page.
Jul 23, 2008 | Lexmark X1290 All-In-One InkJet Printer
Mirror image
Printing Iron-on Transfers
Load the iron-on transfers.
With your document open, click File, then Print. The Print dialog box appears.
In the Print dialog box, click Properties, Preferences (or Options).
Select a print quality:
In the Print Properties dialog box, click the Quality/Copies tab.
From the Quality/Speed area, select Normal or Better.
Select a paper type:
In the Print Properties dialog box, click the Paper Setup tab.
From the Type area, select Iron-on Transfer.
If your software program does not have mirror or iron-on settings, select a print layout:
In the Print Properties dialog box, click the Print Layout tab.
From the Layout area, select Mirror.
Click OK.
To print your iron-on transfers, click OK.
NOTE: To prevent smudging, remove each iron-on transfer as it exits the printer and then let it dry before stacking.
Mar 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
95 people viewed this question
Seeker5211
Seeker5211
