Question about Hotpoint WMA46 Front Load Washer
Front panel connections for Hotpoint WMA 46 washer
Can you help me to identify the wiring connections for the front panel PCB edge connector for the Hotpoint WMA 46 washer? The PCB has the part number AKO 547 004 printed on it.
In particular I am unsure where the three double connectors(one with blue and black wires, one with two blacks and one with two reds) fit on the four pcb fingers marked x11, x9, x6 and x2.
Many thanks
Rod
  • Anonymous Nov 22, 2008
    Following on from your previous solution, could you please confirm where the single green and brown and the single green and red go?
    Many Thanks
  • 135 Answers
Red/red = x2 black/blue = x11 black/black = x9, hope this fixes for you
Posted on Nov 17, 2008
  • pedropony2 Nov 25, 2008
    They go on the last two connections on your right inside a small housing.The red being nearest to right hand side of machine
Wiring diagram for hotpiont wma 50 p
Please check on the link for details on how to identify the parts of the machine
http://www.espares.co.uk/advice/washing-machines/a/7/311/how-to-identify-washerdryer-parts.html
Also there are many visuals for the Hotpoint washing machines in this link. please check these out .
Sep 02, 2011 | Hotpoint WMA50 Front Load Washer
F-07 flashing on display
For most Hotpoint (and other named) models 'F07' means 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause)
Good luck,
John C
Mar 14, 2011 | Hotpoint Aquarius WF000 Front Load Washer
(and again!) Hi from retired Englishman in SW France,
Good luck,
John C
Mar 14, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Display f-01 showing up
"Error F01" is indicating that the motor triac has short circuited on main PCB, this is part of the electronic speed control for the motor.You can do simple checks like motor connections/brushes etc.If the connections are seems to be perfect check the wiring whether it has continuity from motor to PCB. If there is no continuity then the PCB is faulty.
Hotpoint's advice is to call an engineer, it is not really a DIY repair, unless you have a good knowledge of electronics.
Thank you !!
May 25, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wma42. drum not turning, brushes changed last november, have tryed a new motor twice still not turning... suspect pcb. what do you think.
Pcb is a distinct possibility but would check loom from board to motor as i have found many broken wires on wma series.
Hope this helps & thankyou for using Fixya.
Feb 20, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Need wiring diagram to conect pcb to a hotpoint ultima extra wma66
www.selfix-uk.co.uk for manuals on WM & WMA machines including wiring connection charts
Feb 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
Cd cut40d plasma cutter China
From inside the machine follow the wires coming from the front panel control connection. Look closely for you will most likely find either a broken, disconnected or loose wire. The wires from the front panel connection run 1st to a small PCB( 1"x2" roughly) mounted vertically at the bottom front right of the machine frame, you may want to remove that pcb to get a closer look the connections. Wires then leave that PCB and run to a snap in connector on the front left side of the front bottom PCB, check the wiring that terminates in that snap in connector.
Regards, Larry
Dec 29, 2008 | A & A Manufacturing Ramsond 40D Plasma...
PCB connections
follow the wires and find out where they go to then come and will take it from there, on my connection chart I can only see x10 x1 x5 x9 x2 and x4
Jun 21, 2007 | Hotpoint WMA31 Front Load Washer
PCB replacement
it seems that you are talking about the two wires that fit onto the back of the board where there is a black component that is square on the right hand side when looking from the front the wires fit within the black unit. i cannot remember which way around though. i will post again when i next do a wma repair ,tony.
May 22, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Goes straigt to spin
TRY CHECKING THE BOARD ON THIS MACHINE ESPECIALLY THE MOTOR CONNECTION. WHAT YOU WILL AHVE TO DO IS PUT THE DIAL IN TO THE OFF POSITION ( ONLY AS GUIDE ) THEN DISMATLE THE BOARD FROM THE FRONT FACIA. HAVE A GOOD LOOK AT THE MOTOR PLUG CONNECTION SECTION OF THE BOARD CHECK TO SEE IF THERE ARE ANY TRACKS THAT HAVE BLOWN. I RECONDTION WMA ALL DAY EVERYDAY AND I HAVE HAD THIS PROBLEM BEFORE ONCE AND AM THINKING YEH THAT WAS THE PROBLEM. OR IT COULD BE THE TACO ON THE END OF THE MOTOR BUT THIS IS VERY RARE FOR HOTPOINT WMA UNLIKE THE HOOVER MACHINES.
Aug 21, 2006 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
436 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
