Question about Sony Playstation 3 (PS3) Console
PS3 not powering up but has blinking red light.
When trying to power up the PS3 the solid green light comes on, then solid yellow, and then the blinking red light comes on. and thats all it does. Also no video, sound, or anything else is present.
  • 1 more comment
  • Anonymous Nov 21, 2008
    omfg are u serious ima be pissed if i lose all my online data
  • ashley Dec 16, 2008
    the red light just keeps blinking when i turn it on it goes to green then yellow then red
  • freider88 Jan 16, 2009
    my ps3 turns on for 3 sec and then shots off with a red blinking light
Tell Sony !! I did now im gettin a new 80 gig (lost all my online data tho!)
but hey im gettin a new unit plus there sending me cod 5 cos thats stuck in the ps3
sont no about this fault an its not fixable (smoked mother board!!!)
hope this helps..
mine was outa warranty.(60 gig)
Posted on Nov 18, 2008
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
I was watching a Blu-Ray movie this morning and my PS3 just shut off and proceeded to have a red blinking light. I pressed the power button and a solid red light appeared. I pressed the power button...
You have major problems I'm afraid. You need to contact Sony about fixing it/replacing it. Just pray it's under warranty. You could equate this problem with the 360's Red Ring of Death.
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
No power
If you do not know what you are doing, you should contact Sony to find out what the problem is exactly but usually it is due to overheating of the hard drive. Just to be safe, do not try to open the PS3 on your own. If you do not have any warranty or it has expired, it can cost you about 140$ to fix your PS3.
You should not be disappointed and sad when your PS3 gets the blinking red light problem. Most of the times, it is a problem of connection with your hard drive or the hard drive itself is broken.
You can quickly fix the PS3 by carefully re-setting the drive. In order to do this, you need to take out the hard drive and then once out, replace inside the PS3 the same way. Usually this is the answer to the Ps3 blinking red light problem. If the red light does not go away by applying thus method, you will have to get a new drive or in some cases a new PS3, ouch!
But do not worry because even if you have to get a new drive, it can be any. Even a 50$ one will work. And the chances are very small that you will have to get a new ps3 because the method I told you repairs it 9 out of 10 times! That means you can get back to your game!
Aug 25, 2009 | Sony Playstation 3 (PS3) Console
Red light green light yellowlight red blinking light
From what I understand its a problem with the backwards compatibililty(the engine/drive that lets you play ps1/ps2 games)on the 60g.Sony says they have never heard of this problem yet these models are no longer in production.I have had mine for 2 years and it died today,same problem.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
PS3 Green then Yellow flash then blinking red
or you can try to get your money back if you hve a receit i say give it bak and get you a new one. or see if you can find one ebay or game stores
Jun 01, 2009 | Sony Playstation 3 (PS3) Console
Playstation three power problem
This is probably like the "Ring Of Death" that is included also with the Xbox 360. You might need to replace it. Have you been using it over a long period of time?
Apr 26, 2009 | Sony Playstation 3 (PS3) Console
How to fix blinking red light on my ps3?
You should open up the PS3 and use compressed air to dust it off. Take a look at the thermal paste to make sure it isn't dried up! PS3 Flashing Red Light The Ultimate Solution
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,099 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
