Question about Sew D'Lite Lightweight Portable Mechanical Sewing Machine
White d'lite 1750c presser foot in down position not recognized
This was an intermitten problem but now is constant. When the presser fot is lowered an indicator light is supposed to turn green and then you can engage the machine. Instead, the indicator light stays red and naturally, doesn't allow me to begin sewing. There is a needle reset botton that does turn the light green, resets the needle and then the light turns red again. Apparently the needle reset does not require the presser foot to be in the down position to operate. I wouldn't mind bypassing the presser foot indication requirement, but I am out of ideas at this point. No loose wires, no pressure issues....any ideas?
Thanks in advance for helping
  • desapr
    desapr Feb 18, 2013
    Can anyone explain what you mean by putting the bobbin all the way to the left? I saw that in the instruction manual, but don't understand what they mean. What bobbin? The one that feeds thread from the top or the bottom of the machine? I understand English pretty well but I am terrible with mechanical stuff. I have the same problem, the machine worked for a few days and now it is giving me the red light.
This also happens when the bobbin winder is too close to the right-like when you wind a bobbin and don't put it back or not back all the way to the left.
Posted on Nov 23, 2009
Some times if the buttonhole lever had moved this will happen try reaching back moving this back into position if fabric pushes this and moves it the red lite will stay on
Posted on Dec 28, 2008
I occasionally have the same problem with my White d'Lite 1750c. I turn the power off, let it rest a minute, then turn it on again, and the problem goes away for a long time (weeks, sometimes months). Of course, the settings go back to the default, so note your settings before turning the power off.
Hope this helps. Good luck!
Fran CW
Posted on Dec 15, 2008
Hi, My Elna 7000 doesn't easily feed medium or thin fabrics. Presser Foot tension lever is position 2 and the Feed Dog is rising normally. Any thoughts please? Does the F Dog wear out in any way?
Generally, the lighter the fabric weight, the heavier the presser foot pressure. Yes, feed dogs do wear with use. Do not run the machine without fabric between the presser foot and the feed dogs--the feed dogs constantly rubbing against the presser foot will quickly wear the feed dog points. Store the machine with the presser foot down with a pad between the presser foot and feed dogs (even a scrap piece of fabric will do). Also, be sure to clean the feed dogs of any gunky build-up. If the feed dog points are worn, it may be worthwhile to have them replaced.
Jan 23, 2017 | Elna Sewing Machines
When trying to embroider I keep getting a Lower the Presser foot message when it is already lowered!!
You don't state the brand/model of your machine. If it is computerized model, the machine is not recognizing the presser foot's position. If there is a glass eye on the foot, make sure it is clean of any dust, lint, or fingerprints.
Jul 19, 2015 | Sewing Machines
Pfaff 2056
What do you call the presser fot...it is actually the pressure on the fabric
Feb 18, 2014 | Sewing Machines
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
Jan 29, 2013 | PfaFF Creative 7570
How do I install my darning foot?
First, raise the presser bar, remove the presser foot, the presser foot holder and screw.
Turn the handwheel to bring the needle to its highest position.
Place the darning foot on the presser bar and make sure that the metal bar of the darning foot is above the needle clamp and put the screw back on and tighten.
As the needle bar raises and lowers, the foot will hop up and down slightly.
Make sure that you always lower the presser bar when using this foot. Lower the feed dogs also if your machine has this feature.
Aug 20, 2009 | Kenmore 15343
My presser foot won't snap on to my White 3032
It sounds as though you are missing the ankle which is the part the foot attaches to. The ankle attaches to the metal rod with a screw and the foot snaps onto the ankle.
sewman7
Apr 30, 2009 | White Sewing White 3032
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
"Lower presser foot" error on SE 270D
This happened to me and I eventually realized that there is a small door flap at the top near the "4" in the threading series that can get stuck open. Normally this flap goes up and down with the presser foot, but if it gets stuck open even when the presser foot is down, tapping it or closing it manually will make the error go away.1_9_2012_12_19_55_am.jpg
Dec 28, 2007 | Brother SE-270D Computerized Sewing...
How to put on presser foot "p" to embroider
Not shure you can embroider on an MC4000, i think this is only a sewingmachine.
But to change presser fot:
If it a "snap on" foot, when foot lifted, press the "button" on the back of the needle bar (on the bottom) this would release the presser foot.
If is a large foot, you have to unscrew the screw on the left side of the needlebar, and change the whole foot.
Jun 21, 2007 | Janome Memory Craft 4000 Sewing Machine
Sew D'Lite Lightweight Portable Mechanical Sewing Machine Logo
302 people viewed this question
Top Sew D'Lite Sewing Machines Experts
silly01
Level 1 Expert
matty_w
Renee Knafel-Bullock
Are you a Sew D'Lite Sewing Machine Expert? Answer questions, earn points and help others
