Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
My toshiba 42h83 tv has sound but no picture
It was working fine when I turned it off
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Of course check different inputs etc to make sure something did not get disconnected.
This rear projection set uses 3 picture tubes and the set will protect them if there is a problem in the vertical or horizontal sweep circuits that might burn the screens or the damage the tubes.
No simple answer as a lot of different parts are possible for this problem.
Posted on Apr 28, 2012
Testimonial: "much better thank you"
SOURCE:
  • 1694 Answers
SOURCE: Toshiba 42H83
Most projects in life are "easy",if you know how.Chassis will have to be pulled,convergence IC's replaced w/top quality parts to prevent recall.Some excellant soldering will be needed for prevent maintenance,for instance,the steel jumper wires feedig b+ to convergence IC's. RE-align in servicer mode==final step.
Posted on Sep 29, 2007
Slinteriors
  • 8617 Answers
SOURCE: Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Posted on Mar 02, 2008
  • 2920 Answers
SOURCE: Toshiba 42H83 model projection HD tv has a bad wavy picture.
yes it can be fixed call a repairman and have them come out and repair it.it shouldnt cost more than a couple of hundred dollars to fix
Posted on Feb 01, 2009
SOURCE: We have the Toshiba 42H83 Rear Projection TV and
try plugging it in.
Posted on Oct 06, 2009
  • 1030 Answers
SOURCE: picture is distorted on my toshiba 42h83 audio is
Distorted in what way WAVEY? there is a problem in the past with 11 very small capacitors that can cause this did it help when it warmed up? The trouble is these capactors can be replaced. but it take someone whe can do very difficult solder called surface mount. i do maybe 2 a month its very labor intensive i am not saying this is the prblem but this set does have that history
Posted on Dec 10, 2009
My Toshiba 42H83 has a scrambled screen for about 5 minutes when it is turned on, if it has been off for a while. Once it warms up, it works fine. I have replaced the satellite receiver but this did not...
ok, you are talking about lines in the picture, it started where it would clear up after a few minutes but now it will slowly take longer?
I know what is wrong.
SD TECH
Oct 22, 2010 | Toshiba 42H83 42" Rear Projection...
My toshiba 42h83 tv is dead. It won't turn on. I
hello if you've never looked inside a tv before then you'll be wasting your time with out the right equipment it will be hard. get quote from an engineer good luck
regards
shaun
Jul 31, 2010 | Toshiba 42H83 42" Rear Projection...
Control board say not availible when any button is pressed, only shows av1 picture and picture is scrambled, toshiba 42h83 modle rear projection tv
this may be due to a stuck on mode select button control, are you going to try to repair yourself ? do you have a shop manual ? let me know
Jan 30, 2010 | Toshiba 42H83 42" Rear Projection...
The picture is all waves ,I get sound and color but the picture is all lines and waves,what part should I get??
To fix the shaky picture on the toshiba rear projection tv model number 42h83. You need to either replace the 13 capictors on the hyper module or simply replace the hyper module itself. It's cheaper to replace the caps, but you'll need decent soldering skills to do this. You can replace the entire hyper module with less soldering skills, but I believe the module costs about $100, maybe alittle more. You can find the entire fix by googleing "hyper module". Good luck and I hope this helps
Oct 21, 2009 | Toshiba 42H83 42" Rear Projection...
42 in. Toshiba Rear projection HDTV model 42H83
NO picture most offten means HIGH VOLTAGE circuits are not functioning correctly.
which can be caused any myriad of factors.
such as the relay to the high voltage side.
without a schematic you're spittin in the wind.
Sep 04, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba 42H83 rear projection tv turns on but i have no picture or sound. happened suddenly. What can troubleshoot before seeking proffessional hel.
Check all micro-fuses in power supply.If two or three are bad,a convergence circuit O/H will be necessary.Pro help usually required-chassis pull,replace convergence IC's and careful hand- soldering needed to prevent call-back.
May 21, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
149 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
