Question about Whirlpool GHW9100L Front Load Washer
Water Collection in Washer when Machine is OFF
We've had the duet washer system (Whirlpool) for five years now and never had this problem.  A few months ago, we did minor reno and moved the washer/dryer upstairs, last week, we noticed when we opened the front door of the washer (which was empty as it was not being used) to load it, it was about 1/3 full.  I'm not sure if this is a problem with the machine (i.e. could it be a leak?), or if it's plumbing/pressure balance related problem.  It has been used with no problems for the past 3 months (after reno) so not sure if this is related to the renovations, etc.
Anyone with information, please let us know.
  • ElectricMan
    ElectricMan May 11, 2010
    Was it 1/3 full of water? And have you used it since?
    Champion:
  • 248 Answers
You may have something lodged in the pump, pumps easily removed worth checking
Posted on Sep 18, 2009
  • mrhotandcold
    mrhotandcold Sep 18, 2009
    you may have something lodged in the pump, pumps easily removed worth checking
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer door will not unlock or complete the cycle
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
  • Oct 13, 2011 | Whirlpool Washing Machines
    Hi I have a whirlpool front load washer model number ghw9100lw my problem is that i am getting a f05 code i have changed the temp sensor and i am getting the same code i have unplugged the washer now when...
    Check and replace
    - Flowmeter.
    - Water inlet valve
    Make sure to unplug power cord before you replace the part and also make to clean drain tube and filter every year.
    Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Gurgling sound from Whirlpool Duet washer when not in use
    Check your drain line. You may have a siphoning condition. The following link explains:
    http://www.fixya.com/support/r587481-prevent_washer_siphoning
    If you have the water source turned off, the only other way water gets into the washer is through the drainage system. If you do not have the proper air gap or placement on the drain line, it can create a vacuum and allow water to siphon back into the washer.
    NOTE: Some residual water in the drain line is normal.
    If you have any questions, please let me know. I hope this helps you.
    Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Water in drum when washer isn't running
    Water fill valve ..Also.try outlet pipe not too low, water could be comming from sink back into machine...
    Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Water filling up in Front loading Whirlpool washer
    sounds like you have a faulty water valve that does not close when the power is not supplied to the machine.or a problem with the cotrol board supplying power to the valve when the unit is not in use
    Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet- front Load washer
    F 35 Does your machine use alot of water? The pressure switch has failed or the tube has a hole in it. If the machine is new and purchased at Sears it is under a warranty for defects for a year.
    Sep 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Front end Washer
    you have a bad water inlet valve. its not seating properly allowing water to trickle in when not in use. youll need to replae the water valve. in mean time turn water off between uses.
    Mar 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet washer problem
    Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
    Oct 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool GHW9100L Front Load Washer Logo
    76 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
