Question about Kitchen Ranges
Flame way too high and yellow-Frigidaire Model #FGF328GM
We just installed a new fridigaire free standing gas range this past weekend, when ''testing'', the burner flames are very high and ''poof'' when starting (almost dangerous with the high intensity burner!), inside the oven the flames would come out of the vents about 5'' and show no blue at all;   the flames are whitish-yellow; we had attempted to adjust the valve for this and still does not change the color at all.   we had just bought the home about 1 year ago, the propane tank is not new, so we had imagined that there wasnt an issue of it needed to be purged....
any input would be greatly appreciated!
oh...also, the stove which this one had replaced was (much) older and had significantly less btu's than the new stove- there was hardly a flame at all- however, that flame too seemed somewhat more yellow than it should have.  could it be a propane issue?
    Top Expert:
  • Kitchen Ranges Master
  • 48,404 Answers
Call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Posted on Mar 11, 2017
SOURCE: changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Posted on Nov 22, 2007
  • 254 Answers
SOURCE: new gas range converted to propane
I think it sounds like one of two problems either the wrong orifaces were installed in the gas valves for the conversion or the pressure on the output side of the gas valve was not set correctly.
Posted on Jun 22, 2008
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
  • 257 Answers
SOURCE: Propane gas burner now has red flame instead of blue
Hi, If you have the same problem with your stove , furnace and water heater, Then you look for things in common that would cause the problem. Any change in the flames is an indication of a change in the fuel/air mix. The item that would be common to all would be the pressure diaphragm. This is not something a customer should work on without a through knowledge of how they work. I think you would be well advised to have a service call. Good Luck!
Posted on Feb 10, 2009
  • 59 Answers
SOURCE: viking range - gas flame on one burner does not change
It sounds like the repair man was correct. The only variable is the valve, if the rest of the burners are fine then it will be the valve
Posted on Mar 09, 2009
Pilot flame flickers when burners on and drops out valve
You should either do a smoke test or use a candle to check for drafts to be sure that it is not a gas pressure issue.
Aug 13, 2014 | Kingsman FDV200 Free Standing Direct Vent...
High flame on burner
the adustment screw should be at the valve.
Jun 14, 2013 | Frigidaire FGFB75D Gas Kitchen Range
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
My surface burners are burning with a yellow flame. How do I adjust to get a blue flame. Model # FGGF3041KFC
yellow flames indicates blocked gas jets... must be cleaned or replaced before using for safety reasons
Mar 20, 2010 | Frigidaire Kitchen Ranges
High flames in oven
Flame saftey device control valve stuck in open position that why main gas is coming other wise flame should be max 2cm long after flame saftey device heat up and bellow expand and main valve should open
Jul 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven flame is too high
the flame should be app 2" from each side of the burner. be very careful with lp conversions.
Feb 09, 2008 | Frigidaire GLGF382D Gas Kitchen Range
High flames
you need to convert your oven!!!! sounds like you have LP or tank gas, nad your oven is set for naturla gas. theres instructions on how to convert in installation guide, not hard !!!!!
Jan 16, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire convection free standing range
new ranges come set for natural gas. in the installation instuctions there should be instruction for converting the range to lp. some models require that the orafice for the burners be replaced as part of the coversion, if so the there should be a pack of them with the new range. others you just have to tighten the orafices that are all ready in the range. you installation guide will tell you which one you have to do
Nov 24, 2007 | Tappan MGF500PBW Gas Kitchen Range
Kitchen Ranges Logo
958 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
