Question about Lasko 5365 Ceramic Compact Heater
Lasko 5365 Ceramic Compact Heater Troubleshooting Forum.
I have a Lasko 5365 portable heater and for what ever reason it has stopped working properly. Originally the problem started with turning it on high heat it would always shut off within 10 seconds. So it would basically only work on low mode. Now even the low mode is doing the same thing it is turned on and then shuts off by itself. However in the low mode it stays on for more then 10 seconds it can be several minutes, but it is guaranteed to shutdown every time. I am just hoping it could be a simple cleaning or something because it's a relatively inexpensive unit and is most likely not worth putting money into replacement parts. Any suggestions, tips, or hints would be greatly appreciated.
  • jonironi Feb 07, 2008
    Mine have done the same thing....TWO of them. The first year we used them they were wonderful and this year, just out of the blue, NEITHER will work! Runs for 10 seconds - sometimes longer - then just shuts off. Even unplugging and letting it reset for awhile may or MAY NOT work. What the heck???? These things were not cheap and I am highly disappointed in that we bought two of them and now they are totally worthless. DO NOT BUY!!!!!
  • Anonymous Mar 13, 2014
    the heater seems to be on low even though its on high. It will barely heat a small bedroom
  • 4 Answers
Try taking a can of compressed air and spray in the vents in the front and the back of the heater. The heater has a sensor that gets dusty and causes it to shutoff to prevent overheating.
The heater should function properly once the dust is blown off the sensor.
Posted on Feb 19, 2008
SOURCE:
My heater stopped as a blanket covered it by mistake
after letting it cool down the heater should reset it's self and work again...
If it does not then it is no good anymore as the thermal switch is not replaceable...
heatman101
Jan 17, 2011 | Lasko 5365 Ceramic Compact Heater
Heater shows red ready button, but won't turn on. Any ideas? I've already unplugged, tried multiple outlets and vacuumed the heating elements.... ???? What next ????
Turn temperature setting all the way up.
If that does not fix, turn temperature setting all the way down, turn heater off, unplug for at least 10 minutes.
Oct 05, 2010 | Lasko 5365 Ceramic Compact Heater
My heater shuts off after 5 min
i have the same problem ... the fix open the heater and vaccuum the dust in front of the heating element and the back ,,, and the fan ... you have to have the triangle screwdriver ...mine i use the #zero square screwdriver.. after this it works like brand new .. i almost throw this one out ...
Dec 07, 2009 | Lasko 5365 Ceramic Compact Heater
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Dont know what buttons mean
hai sir the button which you are confused in is used only for reseting the equipment.please find your equipment seller for a copy of users manual.
Jan 29, 2009 | Lasko 5365 Ceramic Compact Heater
http://laskoproducts.com/instructions/5364Ins5364ES.pdf
Here you will see what the buntons do.
Good Luck and Please rate Fixya!
Jan 08, 2009 | Lasko 5365 Ceramic Compact Heater
The thermostat does register the right temperature.
Your heater might be on the Auto settings .. it will turn on and off itself once the pre set temp is reached ...
Jan 05, 2009 | Lasko 5365 Ceramic Compact Heater
Heater does not come back on
I found that if I unplug the heater from the power outlet for about 3 to 5 minutes, it goes back to normal. Ive had my heater about 1 year, and have successfully done this twice. Hope this helps~!
Dec 17, 2008 | Lasko 5365 Ceramic Compact Heater
Will not stay on for more than a minute, reachers 57 degrees and turns off, can not be turned on again.
Feb 11, 2008 | Lasko 5365 Ceramic Compact Heater
Won't shut off when reaching preset temp
The heater shuts off when it reaches two degrees above the set temperature and turns back on when it is two degrees below.
Dec 13, 2007 | Lasko 5365 Ceramic Compact Heater
Lasko 5365 Ceramic Compact Heater Logo
852 people viewed this question
Top Lasko Heating & Cooling Experts
Craig Butler
Craig Butler
Kenneth Walker
Andrew Taylor
Andrew Taylor
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
