Question about Gateway Computers & Internet
Our laptop has a broken screen. are they replaceable?
Yes, you need to check first with the technician which part can be use and parts needs replacement.
Posted on Nov 17, 2008
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
Asus Laptop Screen is broken
Search ebay for the screen.
The link below will tell you how. How to replace broken laptop screen
Mar 26, 2014 | Computers & Internet
Blaupunkt Tablet ETAB0507 broken screen
this come with the screen and lcd separated buy only the touch screen and it gona work again change it
Jan 22, 2014 | Computers & Internet
Broken laptop screen
There is nothing more frustrating than a broken laptop screen. Whether you have dropped your laptop or stepped on it,once the screen is cracked it has to be replaced. Having the screen repaired may cost you almost as much as a new laptop. Purchasing a new screen from the manufacturer can also be expensive. Taking the time to look online at computer message boards or resellers can help you to find a reasonably priced screen. By following a few easy steps, you can replace your cracked screen and have a functioning laptop in an afternoon.
Determine what model laptop screen will fit your laptop. Ordering a screen directly from the manufacturer can be almost as expensive as buying a new laptop. Look at online computer message boards, auction sites and retailers to find less expensive options. Disconnect any power source, including the battery pack, from your laptop before you begin. Locate and remove the four to six screws that hold the bezel, or plastic frame cover, in place. The screws sometimes have small plastic or rubber covers over them. Pull the plastic bezel away from the screen cautiously, working around the edge. Some bezels snap in and out of place. A small flat-head screwdriver may be helpful in prying the edge of the bezel away from the screen. Pull the screen forward gently. You will find two main wires behind it. The ribbon-like wire, or video cable, is usually taped in place. Remove the tape and disconnect the video cable from your broken screen. Remove the broken screen from its metal frame. Connect the new screen to the video cable and pop it into the metal frame. Replace the tape, plastic frame and screws. Power up your computer and test your new screen. Hope this helps.
Dec 10, 2012 | Computers & Internet
Samsung laptop broken screen
go to samsung authorize care centre.they will fix ur screen
Nov 29, 2012 | Computers & Internet
Broken screen
Sellers on ebay take broken laptops and part them out. Search for a replacement screen/display there and bid or buy one from a top rated seller that you can afford...factor in the shipping prices before you decide.
Jul 25, 2012 | Toshiba Computers & Internet
Broke the screen on my cob kyros can i get it fixed?
A broken screen isn't something which can be repaired with a software upgrade. There are two types of broken screens. An internally broken screen is where the image on the screen looks cracked, even though there is no physical signs of abuse. It will turn on but you'll see all these funny colors come onto the screen. An externally broken screen is basically if you took that laptop and dropped it onto something hard. You wouldn't get an image, you'd just hear some noise from the power supply.
Your best bet if you have a broken screen is to take it to a service technician to see what a screen replacement will cost. If the laptop still works you can also plug an external monitor into it. This won't let you use it so easily on the go, but at least you'll be able to use it at home.
Hope that helps.
Jan 02, 2011 | Coby Computers & Internet
I dropped my laptop on the floor, it fell on a corner, the screen is scrambled on the right side for 1 inch and the top right corner is black like a broken window what shouls I do? Thank you
You can either replace the screen or you can work on your laptop with a broken screen. Replacing the laptop screen is quite costly depending on your laptop model and availability of your parts.
Jul 27, 2010 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
