Question about Viper Security and Remote Start System (basic install included)
Viper 791 XV Automatic Start Not Working
I have a Viper Automatic Start system installed in my 2000 Honda Civic. It's the 791 XV model and was already put in when I bought it 1.5 years ago.  The automatic start has been working completely fine until last week when it suddenly stopped working.  It literally worked earlier that day. The keyless lock/unlock feature still works fine.  The alarm system still works fine as well.  It's just the automatic start.  It's not turning over or anything.  When I push the button, the antenna symbol still comes on the screen, but nothing happens.  HELP!! It's getting colder everyday where I live :)
Thanks so much I have a viper remote and it wont start the car anymore. The alarm function still operates just fine but it is cold outside and i am unable to start my car from inside.
  • bmaxwell2 Jan 16, 2009
    my car turns but it wont fire up i think it might be the anti-theft module any idea where it it is reasonable to get one of these the viper is on my 1998 gmc
  • 22 Answers
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Posted on Dec 04, 2008
I have a viper 791 vx installed in a 99 bonneville. The key will turn the engine over but won't start. The remote start will start the car but I put the key in and push the brake and the car dies. I had...
Get rid of the junky viper and get a bulldog rs82b and you will never have a problem...I have installed over 40 of these since November and NEVER had any problems....
Feb 03, 2015 | Viper Vehicle Parts & Accessories
My speedometer is not working. we already try to replace a new sensor and panel gauge but still is not working. Electerical was also checked and there were instances my speedometer works but suddenly it...
if speedometer and odometer are not working, chances are that the speed sensor is bad and stopped working. find vehicle speed sensor on transmission, the connection may be corroded or the sensor itself is bad. good-day !!
Jul 07, 2011 | 2000 Honda Civic
My viper car starter wont work consistantly lately,sometimes the remote works and i will press it again and nothing,changed battery. its a hit and miss thing. im confused.its a 130 xv model
sounds like a dirty remote. if you open it up and clean the contacts with rubbing alcahol (get the back side of the rubber as well) it should help
Mar 07, 2011 | Remote Start System
Can i install remote central locking for 91 civic already has central loc not working
depending on the model of your civic. If it was an option when the car was first bought from HONDA back in the day then you can have anyone or honda install a kit for you. Good luck
Aug 11, 2009 | Honda Civic Cars & Trucks
Car is completely locked down
Let's hopethat the installer actually put in the valet switch for the Viper! Lcate the valet switch. ALWAYS put mine down by the e-brake lever under dash. (I assume that the alarm is going off? If not, go to next step.
Find the alarm/start brain under dash. Unplug main 6 pin 12 gauge wire harness. Wait 5 minutes, then re-appy the power plug. Alarm "may" go off, then try again.
Hit me back if you need further assstance. TTYL
Larry T
Winona Lake, IN
Jan 28, 2009 | 791XV The 791XV is a 2-way Security and...
Viper Working installed in my 2000 Honda Civic. It's the 791 XV model I nite diagram
Nov 05, 2008 | Viper Security and Remote Start System...
Viper 160XV Problem
How to programing the remote for viper 160 xv.Thanks.
Jul 02, 2008 | Viper Security and Remote Start System...
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
484 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
