Question about Electrolux EOB5610 Ultrafan Electric Single Oven
Replacing electrolux eob944 fan oven grill element
I have purchased a relacement grill element for the electrolux eob944 electric fan oven but cannot remember the wiring connections. Does anybody know which cables go on which blade terminals.
  • Eric Mason May 11, 2010
    David how many connections are we talking about (2/3)??
    If its ONLY two it does not really matter, but if any more, you will need to identify whats what.
  • Anonymous Mar 13, 2014
    Model EOD5330W
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Posted on Jul 08, 2009
How many elements are there
If you ask how many heating elements is there then my answer is two. Upper heater element with grill heater (1000 / 1900W) and ring heating element (2400W) that is positioned around the convection fan.
Dado
Jun 27, 2014 | Electrolux EOB5630 Ultrafan Electric...
No heat when fn oven is on light works as does grill & base
If the fan is working o/k, then you need to replace the oven element located behind a removeable cover at the rear of the oven compartment.
Nov 23, 2010 | Electrolux EOB6632 Electric Single Oven
Elextrolux Oven stopped generating heat. Grill working ok. Sparks came out of Fan area followed by cloud of ash. What could be the possible cause and what part could be required ?
Hi.
It will be the oven element that has failed.
This is located at the rear of the oven compartment where the the fan is.
Remove the cover at the rear of the oven there you will see the oven element, a very easy job to replace.
Nov 10, 2010 | Electrolux 30" Built-In Single Electric...
Oven not working but grill and other functions are. Fan also working think it might be fan heating element
You can easily buy parts online...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 19, 2010 | Electrolux EOB6632 Electric Single Oven
Oven is not heating. Fan is working and grill wor...
This would appear to be the ring element around the fan that has failed and will need to be replaced.You will need to power off unit,then remove the back panel inside oven 4 screws in corners,Be careful with Thermostat held in place by clips above or on back panel.You may find 3 or 4 screws holding ring element.Gently pull towards you,being careful that the cables come with it.Check element with multimeter to see if open circuit if its ok then it may be a thermostat fault.If it is a faulty element,
get your replacement element,remove the cables off old one and put onto new one.Then push back into place and refix all.
Hope this helps.
May 21, 2010 | Electrolux EOB6630 Ultrafan Electric...
Replaced fan oven element but now now fan and no light
remember to set the time of day on the clock it wont work until you do.if you have done that then it could be clock relay contacts that are faulty.
May 20, 2010 | Electrolux EOD5330 Ultrafan Electric...
The grill works, the fan works but the oven doesn't het up
If the fan is working o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Sep 08, 2009 | Electrolux EOB5610 Ultrafan Electric...
Electrolux EOB5630
Not sure that I can help but will certainly try. You need to check to see if the power is getting to the oven. As the grill, light and fan are working it seems that it is. With the Oven not heating up I would suggest that it is possibly the Oven Element. Usually to check these you need to remove the cover inside the oven and also the back cover. You will probably find the power is getting to the element but the element is not working and needs replacing. Before removing it MAKE SURE YOU TURN OFF THE POWER TO THE OVEN. Should only be 2 or 3 wires going to the element which will need to be removed before removal. Usually only a couple of screws hold the element in and once removed you may have to wiggle the element a little to get it out. Replacement is just a reversal of the removal procedure. I had to replace the one in our oven 2 weeks ago as we had the same problem. It is fine now and was only the element. Just MAKE SURE you TURN OFF THE POWER before removing the element. Hope this helps.
regards
Bryan
Nov 16, 2007 | Electrolux EOB6636X Ultrafan Electric...
Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Sep 20, 2007 | Electrolux EOU6330 Electric Double Oven
Electrolux EOB5610 Ultrafan Electric Single Oven Logo
1,241 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
