Question about Brother P-Touch 1180 Label Printer
ERROR appears and won't print
I was attempting to change the font size and not sure what I did but now the arrow points to Style and Firm. I'm working with a Brother P-Touch 1180. Not sure what to do to get the error removed and printing again. Thank you in advance for your help
What size tape are you using in the machine?  Some of the fonts won't work if you are using 1/4" tape.  It will say ERROR if you're asking it to print a larger size. This won't be a problem for you if you switch to 1/2" tape, or just use the two smallest font sizes.
Hope that helps!
Posted on Dec 17, 2008
Font is very big
Hi jjsbeach...
You need to check two places to see about reducing the font size.
Note: > ...means to go to or next
1...Look in the right hand corner at the bottom of the page and you will see may see 100%...if you do not then click on the arrow down and a window will open allowing you to size the window from 50% to 400%.
2...Left double click "Start">Control Panel>Appearance and Themes>Display>Appearance, look down at the font size and make sure it is set to "normal"...
If you are sending an email and you want to make the font smaller,larger, or a different style then you will need to open your email and look at almost 1/4 down the page on the left hand side of the page, you are looking for a tiny pair of sissors in line with other items, in that row you can change your font/style/size.
You can adjust the size of your font/change font style, etc. all from the bottom of that window
Please take time to rate me
Aug 01, 2011 | Computers & Internet
Don't panic if you've never pitched a tent before. It seems scary when you first get started but with a bit of practice you will be doing it within minutes.
The most important thing is to practice putting it up before you go on your camping trip. There's nothing worse than the sun setting and no light left around you as you struggle to pitch your tent.
Here are my tips to help you get started: Make sure the area where you want to put your tent is clear, without any rocks or big bumps underneath, otherwise you won't be comfortable.
Don't pitch your tent on a low lying ground. If it rains - your tent site will be flooded.
To protect your tent you should lay a groundsheet down as tents can be damaged by punctures and moisture. Now take out the poles and insert them into the proper sleeves of the tent. The instruction manuals are usually pretty straight forward and helpful. Place both ends of the pole in the metal rings and the poles with flex as the tent begins to take shape. Straighten the tent by pulling the material straight and making sure the poles are stretched taut to the outer point. Now secure the tent into the stakes at the corners. Make sure they are really firmly in the ground so they can resist wind and being knocked into.
on Aug 20, 2012 | Camping, Backpacking & Hiking
How do you change the print size on printer?
You probably don't. Instead, you change the font-name and font-style and font-size on you computer (using Notepad, or Wordpad, or Microsoft Word), and then print in the "what you see is what you get" appearance.
Oct 14, 2010 | Lexmark Office Equipment & Supplies
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
Printing envelopes from from the MP tray on a Canon Imageclass 4350d - after printing I get a message asking "use current size". If I say yes it prints again, if I say no it prints again.
This can likely be solved with one of the following solutions.  If these do not work, please feel free to contact me at social(at) Thanks! This can likely be solved using one of the following solutions. If these do not work, please feel free to contact me at social(at)
1) Change the Printer Options - Enable L90 Only
2) Set Paper Feed to "MP Tray" and Change Printer Options to Enable EF only
3) Change paper size on printer to "B5"
!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-alt:"Calisto MT"; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-alt:"Century Gothic"; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} @font-face {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:modern; mso-font-pitch:fixed; mso-font-signature:-1610611985 1073750091 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} p.MsoPlainText, li.MsoPlainText, div.MsoPlainText {mso-style-noshow:yes; mso-style-priority:99; mso-style-link:"Plain Text Char"; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.5pt; font-family:Consolas; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} span.PlainTextChar {mso-style-name:"Plain Text Char"; mso-style-noshow:yes; mso-style-priority:99; mso-style-unhide:no; mso-style-locked:yes; mso-style-link:"Plain Text"; mso-ansi-font-size:10.5pt; mso-bidi-font-size:10.5pt; font-family:Consolas; mso-ascii-font-family:Consolas; mso-hansi-font-family:Consolas;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} @page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} -->
Aug 25, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
I need to change the font style on my computer as it was recently repaired and has come back with a font style that is too small
Go to
Control panel
double click "Display"
click "Appearance"
At the botoom you will see font size
Click arrow to the right of "Normal"
You can then select Large or extra large
Sep 15, 2009 | Microsoft Windows XP Professional
Can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Jan 04, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Changing font on PT-65
Hold down the [Code] key and press the [&] key to change text size.
There are five different size/styles of text shown at the top of the screen. Keep holding down the [Code] key and tapping the [&] key until the little arrow is pointing at the size you want.
(It doesn't change the display on the screen, so you'll get to play and print out lots of tests - in the name of science!)
Jul 22, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Font size
If you continue to have problems changing the size, make sure the 'bent arrow' next to the BS key is not on. Once I took that off I was able to make the need adjustments to my size and style.
Feb 13, 2008 | Brother P-Touch 1180 Label Printer
Brother P-Touch 1180 Label Printer Logo
324 people viewed this question
James Cagle
James Cagle
Jim Keysor
