Question about Intel Computers & Internet
Maya software not working properly on windows xp
I have installed maya 8.5 personal learning edition. but everytime an error occurs and it closes.
i can't understand the problem.
please help me out
  • basbhikaro Nov 18, 2008
    which graphics card is more appropriate for using maya 8.5
Have you check if your computer pass the minimum requirements of your software(maya)
Posted on Nov 17, 2008
Software Error?
Yes it is. Try re-installing the software. If that does not help, re-install your operating system and install the software. If that doesn't work as well, try replacing RAM. Most often the software works after re-installing it or the operating system, but their might be a chance of H/W failure. However, H/W problems are not so common with the type of error message you are getting.
Also, please see if the device (you are using the software for.. like some camera or a scanner) IS CONNECTED to your system properly.
Oct 30, 2015 | Microsoft Windows XP Home Edition
Ntvdm cpu encountered illegal operation Hi all! I just installed Maya 2010 from a torrent file and since then I got this famous error message. It's just appeears as three command prompts appearing at the...
If I am reading this right your issue is not the application but where you obtained the application. Maya 2010 is a modern design application and comes in 32 & 64 bit versions. It is not a 16 bit application.
When Windows encounters a legacy application it calls the NTVDM for the legacy application to run in.
The fact that the application is calling the NTVDM is highly suspicious. NTVDM is the NT Virtual Dos Machine, a way for legacy applications to run in NT environments.
NT environments are Windows NT 3.5, NT 4.0, Windows 2000 Professional, Windows XP (Home, Pro & Media Center Ed), Vista (all versions) and Windows 7.
Old (legacy) applications written for 16 bit date back to Windows 3.1 and include Windows 95, 98 and Millennium Edition.
I would obtain a copy of Maya 2010 from a reputable outlet instead of Bit Torrent as "warez" frequently contain malicious items that will infect and ruin your machine.
Feb 05, 2010 | Microsoft Windows XP Home Edition
Yahoo messenger closes automatically evrytime i logged-in
Delete or Uninstall it and then install it from net,your problem will be solved 100%...........
Sep 21, 2009 | Microsoft Windows XP Home Edition
IS034 Error when intalling driver software for MFC-490CW on vista
This issue is cause when the print spooler service isn't running, MFL pro installs the printer driver 1st (after paperport install) which will not wun if the service is disabled
Sep 11, 2009 | Brother MFC 490cw Color Inkjet...
Window xp cd cant work properly
this problem occur if ur current OS is newer then ehat u are trying to install.
If u want to install a new Os then use this software
Apr 17, 2009 | Microsoft Windows XP Media Center Edition...
AGV 8 (build 233) Installation
Make sure all other antivirus software is removed before you try to install it.
Also, run a scan for existing infections with an online scan like TrendMicro = or
Feb 03, 2009 | Microsoft Windows XP Home Edition
My PC (Windows XP) refuses my N70 phone now.
Are your other PCs running Windows XP?
The N70 installation on your XP computer did not install properly, it may need a software/drivers for Windows XP.
The driver may be corrupted, download the drivers from the manufacturer's WEB site. there may be a later version.
There may be a hardware conflict, eg. IRQ, memory address etc.
Feb 03, 2009 | Toshiba Satellite A135-S4527 Notebook
Microsoft windows installer
this message pop up only when your OS is damaged. try and repair your window Xp and then reintall whatever you want to install. it should work. but if it continues, then check on your RAm, there may be damping, try and replace it. Good luck
Jun 29, 2008 | Microsoft Windows XP Home Edition
Editing text
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Computers & Internet Logo
67 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
