Question about HP OfficeJet G85 All-In-One InkJet Printer
Printer keeps saying paper jam but paper come through but it wont
Won't print I have checked it and can't find any paper anywhere. I unplug it and then turned bacvk on and it still says paper jam
  • banddneifert Nov 20, 2008
    you did what you could thank you.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
printer keeps saying paper jam but paper come thro - c220ca5.jpgThere is still a piece of paper on a sensor or a sensor is bad
look for a sensor like this it should have the flag in the UP position as seen,
Posted on Nov 17, 2008
  • CheckitRight
    CheckitRight Nov 20, 2008
    Don't give up yet, there are three places to look
    1-the tray
    2- the registration ( look for a black spongy roller, there should be a sensor right before it)
    3-the fuser ( exit where it gets hot, open back door )
Wont print....it says paper jam....but not paper is jammed. what to do?
make sure you check the manual and open all inspection areas to remove any scrap paper, its normally the cause
Jul 21, 2014 | Canon PIXMA iP1600 Printer
Paper Jam error
unplug the printer and then restart your computer and plug the again. if not work, please try cleaning some part of the printer inside by blowing air.
Jan 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam message wont clear and alow printing, I have opened every possible area and there is no paper anywhere. I was printing fine when if gave me the message. the piece of paper it was printing at...
Check if there is a reset, or clear message function. or you may try this one:
1. With the printer turned on, if there is a door for the cartridge, open it.
2. Then, if there is a "Go" button, "Print", "Copy" button, press and hold it for 10 sec.
3. Close the cartridge door or cover. Turn it off then turn it on again.
Please advise what will be the result.
thanks
Jun 23, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer wont scan
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 21, 2009 | Lexmark X2500 All-In-One Printer
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Paper Jam
maybe there is more than 1 piece of paper jamed
Jun 29, 2009 | HP LaserJet 4 plus Printer
PRINTER SAYS PAPER JAM 23 ..
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
thanks J
Jan 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
117 people viewed this question
Seeker5211
Seeker5211
