Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
Dyson dc14 power button
The vacuum turns on, but will only remain on if the power button is held down.
  • Anonymous Jan 23, 2009
    I have the same problem. My Dyson DC14 turns on but only stays on if you hold down the power button.
  • Scott Weber Jul 18, 2013
    Great suggestion - worked for me too! Just curious - did anyone ever need to ultimately replace the switch?
I just had this same problem tonight. As I was looking on this sight to find a solution, my husband fixed it. First he removed the extended handle part, then he took the 2 screws out behind the power switch and removed the front cover (directly underneath the power button). He then removed the plastic power switch cover and took the power leads off the switch and removed the switch and tapped on it, then the little button stuck in place:) Sounds silly but it worked! Good luck!
Posted on Nov 30, 2008
  • Michele Sanborn Apr 01, 2013
    I had the same issue and was planning to take it to the repair shop. Read your review and it took my husband 10 min to have it up and running again. Thanks much. I have the DC19 Animal
I tried this and it fixed my problem. 10 minutes later...the Dyson was up and running again.
Posted on Dec 19, 2008
Worked like a charm! Now my wife thinks I'm MacGyver! Thanks!
Posted on Oct 26, 2012
How do I fix the power button for my Dyson DC14?
  • You will need to remove the switch cover and replace the main power switch.
Jun 29, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson dc14 brushes not turning
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC14's brush bar isn't rotating. This could just mean that the brush control is set to 'Hard floors' rather than 'Carpets'. To check for this, please take a look at our Support guide:
http://www.dyson.co.uk/support/dc14/dc14-all-floors/my-machine-is-not-working/i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating2/does-the-brushbar-turn-with-the-power-on
If you'd like further advice after running through these checks, you can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 04, 2013 | Dyson DC14 Bagless Upright Cyclonic Vacuum
My dyson dc14 all floors won't stay on when I press the power button. I can hold it down and it will work, but that makes cleaning very slow.
Quick Fix...takes 4 minutes max
Remove the switch by using instructions here:
http://www.sparesaver.com/vacuum-spares/help-and-support/dyson-section/dyson-technical-advice-450/dyson-dc14-technical-advice-474/replacing-the-cable.html
(The was an additional torx screw 3 " below the one in the directions...yours may have this too...just remove)
Then...While holding the body of the switch in one hand, use your other to hold both contacts between your thumb and forefinger and gently place pressure on each contact in the opposite direction, just like screwing a nut onto a bolt. Press the switch down while applying this torque and see if it sticks. If it does just bend the contacts slightly and continue pressing the switch to ensure it holds. Reinstall switch.
I still advise buying a switch from amazon for $4.00 and replacing it but this will help you to continue to use your vacuum in the meantime without having to hold the button...
Aug 11, 2011 | Dyson DC14 Telescope Reach All Floors...
Have a DC25, I can not return the handle to the upright position. Nothing appears to be broken
Occasionally, customers have problems locking their Dyson vacuum in the upright position. This is a minor problem common with the Dyson DC07 and DC14 series and can easily be fixed by the customer. This page will show how to fix this problem. Although we show a Dyson DC14 Animal on this page, these instructions will work on any Dyson vacuum in the DC07 and DC14 series.
During shipping, moving parts on a Dyson vacuum can shift in position. One of these parts is a swinging arm in the base of the unit. This arm holds a removable elbow pipe in the vacuum's air passage. This arm can move out of the way so that you can clear out a blockage in the air passage. When this arm is out of position, the vacuum will not lock in the upright position. Fig. 1 Shows the base of a Dyson DC14 Animal locked upright. The red arrow points to the swinging arm. Fig. 2 shows the vacuum with the swing arm out of position. Since the swing arm is lower than it should be, it doesn't line up with the tab on the main body indicated by the red arrow.
Lean the handle of your Dyson all the way back and locate the black button on the right side of the vacuum indicated by the red arrow in Fig. 3.. Press the button down and hold it to unlock the swing arm.
While holding down the black button, pull the swinging arm (Shaded red in Fig. 4) all the way up. Fig. 5 shows the swinging arm in the correct position. Release the black button to lock the swing arm back in place.
The vacuum can now lock in the upright position as shown in Fig. 6. Note how the tab on the swinging arm overlaps the tab on the main body..
dcramer531_17.jpgdcramer531_18.jpgdcramer531_19.jpgdcramer531_20.jpgdcramer531_21.jpgdcramer531_22.jpg
Dec 11, 2010 | Dyson DC25 All Floors Bagless Upright...
I cannot get my vacuum in an upright position. How can I do this?
Try this quick repair and see if this fixes your Dyson:
Step 1.
Turn power off and unplug the machine.
Tilt the machine backward to a 45° angle.
Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    I hope that this was helpful to you. Please feel free to use the Clarification Request form here on Fixya if you have any questions.
    Thank you,
    Chris J.
    GoVacuum.com
    Apr 12, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dyson dc14 vacuum cleaner ,the power, off-on switch does not work
    Take it back - the power on switch button sounds like its being tempramental and it shouldn't do that. It would have to be repaired.
    Mar 31, 2009 | Dyson DC14 All floors Bagless Upright...
    Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
    2,439 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Nick Olsen
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
