Trying to connect to my home wi-fi using laptop with installed linksys wpc54g wireless adapter but the problem is when i use linksys utility it starts, but can't find wifi lans i see frozen word searching and nothing happened.. When i tried to configure it through the windows it ask me a network key, i put my wep key and then laptop trying to connect but says connection is limited or no connectivity.. I tried to remove and install it again but the same story
Limited or no connectivity means your wlan not communicating with the router, check if you turn on the wlan switch on your laptop or try to install updated driver for you wlan
if thats a external wireless lan card try to unplug and plug it back.
Posted on Nov 17, 2008
WPS button
I have a WRT54G router and there is no WPS button.
This is a cut and paste from Cisco engineer:
Wi-Fi Protected Setup or WPS is a somewhat new feature on most routers. However, I believe that the WRT54g was release prior to this feature. The installation disc for your wireless adapter is trying to circumvent network discovery and the process of entering a wireless password by using the WPS feature. Without using the installation disc to setup the adapter should still be able to connect to your Wi-FI network. Only use the disc to install the drivers for your wireless card and the wireless access utility. After you have done this:
1.Open the wireless utility and you should see available networks
2.Select your Wi-Fi network
3.If the network is open (not password proctected) you should be connected immediately
4.If the network is secured (password protected) then you will prompted to enter your password or preshared key
5.After entering the key you should be granted access to the network
Apr 19, 2014 | Linksys Wireless-G WRT54G Router
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
Cannot connect to access point
Are you using the Linksys utility to connect to the wireless network?
If you are using that then you can switch over to windows utility.
It is very simple to connect to the wireless network.
Click Here for More info
Oct 07, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
My Dell laptop won't connect with my Linksys G wireless router
First check in your laptop wi fi switch is turn on if you have laptop.
Then check in computer that wi fi network adapter driver are installed correctly and enabled .
You can check it in my network places right click on it thne go to proeprty then you see there wi fi network driver then enable it.if disable.
Then you can see search for available networks.
If not works then post here so i give you assistanse for router configuration.
Let me know if you need more assistanse.
Aug 31, 2009 | Linksys Wireless-G WRT54G Router
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys WPC54G Wireless-G Notebook... Problem:
Your computer locking up could be a spyware or virus program taking over your machine as soon as you get an internet connection.
Try connecting the laptop to a wired connection and see if it does the same thing.
Run some virus scans from trend micro.
If you can re-install the software for the wireless card. This might help too.
Firefox can freeze your system but highly unlikely from a fresh install.
best wishes.
Oct 31, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
"WPC54G is not installed"
Those install programs that Linksys uses are terrible. This happens all the time.
You probably can't use the linksys program to install the software on a Windows 2000 machine you should be able to install just the driver you need. I have never used wireless networking on a Win 2000 computer before. Win XP has sotware already built into the operating systems to deal with wireless networking.
Uninstall all Linksys wireless networking software. Restart you computer with the wirless network card install and let Windows search for the correct drivers on the CD.
Jun 22, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Compaq Evo with wpc54g v.1 wireless adaptor
hello!
-- make sure that the wireless settings of your router match the wireless settings if you are using the utility of the linksys adapter
-- make sure also that you dont have any firewall or any security on your computer
-- you may also try disabling the adapter wireless utility and use the wireless xp zero configuration instead.
Apr 12, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Can not connect
It is possible that your windows update messed up the Linksys drivers. If your pc is xp, download the latest drivers from www.linksys.com/download. uninstall the wpc54g on the add/remove programs.
if using XP, reinstall drivers only, no need to install the linksys software. This would be best if you install the drivers manually. After this you will be using only the WINDOWS UTILITY for your wireless connection.
Feb 27, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
No association with access point
Another thing to check, (especially if you have installed SP2 in the midst of this process of trying to get the Linksys WPC54G drivers  installed).
In Device Manager, check under the "network adapters" category and see if there's any "other" things with a yellow question mark - I clicked one of those, had it search for the new driver, and after a few minutes it eventually installed a WPC54G driver and placed it in the "Network Adapters" category (I had already run the drivers install from Linksys, Broadcom, many times over - de-installing each time to try another version).
Funny thing about it, when I hit "update" or whatever on that yellow question mark icon - it had given me no clue whatsoever that it was a wireless adapter driver that it was updating.
Hope this helps.
Teddy
"Messianic Roots Reggae from Jerusalem" http://www.Yerubilee.com
Jan 28, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
