Question about Toshiba 55H70 55" Rear Projection Television
Toshiba Theaterview HD 52"
My Toshiba has a blinking red power light but a black screen and no sound. It appears that power is getting to it and, when I turn it on, it makes a noise as if it is starting up but it does not. It is onlyu five years old. can anyone help?
  • 1 more comment
  • Anonymous Apr 09, 2008
    Blank screen no sound, itermittent red flashing light, tried unplugging it and replugging after a day same problem
  • bonzz Apr 09, 2008
    Toshiba model TP55H60, blank screen, no sound, blinking red light next to power button. Tried the so called hard restart (Unplugged for days) still the same problem. Note the TV is almost 10 years old. Any solution besides buying a new one?
  • MrDavis May 11, 2010
    I have a Toshiba Theaterview 61" i fixed the power it turns on i fixed the sound so now you hear sound but the picture is not showing up its like red, green and blue lines in the center of the screen like the screen will not spread out can so one help i have 3 tvs with this same problem can i just cant find the source to it
I have the same tv and had it fixed the problem is most likely the power supply a $50.00 part but I suggest you have a repairman do the fix. Total cost should be around $250.00 for labor and parts.Also unplug your tv for over 4 hours then plug it back in to see if it works they call this a hard reset.If this does not work after 4 hours try unplugging it overnight and then try it. That is what I did to use the tv until I got it fixed. The only thing it could be is the convergence circuitv if this is the case it should cost about $400.00
Posted on Dec 24, 2006
I have the Toshiba Theaterview. Was watching it when I heard a sound and the screen went black. The Red Light will come on and glow steady and you hear it click when you try to turn it on or off but...
Something is causing the TV shut down or go in to 'protect' mode.
It is unusual to actually hear a component inside the TV go bad, but you obviously did. Probably in the main power supply or something that normally uses a higher voltage in the TV since you heard it..
Jan 25, 2015 | Toshiba Televison & Video
No picture just black screen
sounds like the lamp went out in it. change lamp and u should get sound and picture
Apr 23, 2013 | JVC HD-52G886 52" Rear Projection HDTV
Have an older Toshiba theaterview TV, when turn on, we have no picture, no sound, just black screen and blinking red light that just continuously blinks.
Theaterview suggests a rear projection--in that case it most likely is in the convergence circuit--unsolder chips (convergence) and see if set turns on.
Some of their regular TV sets (picture tube) if the light is just blinking means the same thing=shutdown because of a short/problem but a model number would tell me which you have.
May 23, 2012 | Toshiba Televison & Video
My Toshiba 50H81 screen black, no sound & power light blinking
sounds as if your power supply needs to be repaired. the capacitors over heat and crown or leak.
Jan 01, 2010 | Toshiba 50H81 50" Rear Projection...
Screen remaining black after the TV is turned on
Some newer sets appear that way when there is NO signal to the set. That and my Sony looks like that when the bulb is burned out.
Dec 23, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
On my toshiba I just use the input button on remote.
May 12, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba theaterview HD 52" has black box on screen
sound like to me caption 1 is turn on .. try going into settings menu and shutting off close caption...
May 05, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba theaterview
What is the model number?
Jan 03, 2008 | Televison & Video
Toshiba theaterview tz50v51
my guess would be flyback however your lucky you might be able to see a burnt spot on the board giving you a better clue.
Nov 25, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
1,167 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
