Question about HP LaserJet 3050 All-In-One Printer
Scanner not set up
When I moved, I seem to have lost the scanner capabilities. How do I go in to fix it? Says "Scan To" is "Not setup on PC" and "scan" button activation just shows "waiting for PC." Thx.
  • blackcrow Dec 03, 2008
    saying scanner not set up
  • ephdunn Dec 12, 2008
    Thank you. Unfortunately, I can't find my software and HP is not helpful once the warranty expires.
  • 47 Answers
Have to uninstall and reinstall full software solution. First uninstall using the hp program, then use add/remove program uninstall Image zone, extended capabillities and HP update, restart pc and search for scrubber in Hp software it's in utility folder, ccc, doubleclick it to work. then you are ready to reinstall the fully software.
Posted on Dec 08, 2008
My scanner is not returning it seems to be stuck
I have had good luck fixing that problem by opening up the scanner and cleaning the rails with alcohol then very lightly lubricating them.
Feb 28, 2015 | HP Scanjet G2410 Flatbed Scanner
Need to scan docs from scanner to pc
You have to install scanner and printer software came along with the HP 3030 model.Once setup complete it will try to do self diagnose the scanner connectivity.Then when you press the button on the scanner ,scanner will send the data to pc to activate the scanner software automatically.
Nov 26, 2012 | HP LaserJet 3030 All-In-One Printer
I have hp laserjet 3330 all in one , can not use for scan- say wait for PC what can I do?
The link between the scanner and the PC has been lost. You need to run the scan setup from the toolbox on the PC again and this will fix the problem.
Apr 05, 2011 | HP LaserJet 3330 All-In-One Printer
Our computer maintenance company was able to set up our scanner about three months ago. Over the weekend we have lost that capability. We are receiving an error message: Setting how do I fix scanning...
Click this LINKfor the Scan to SMB setup guide which will walk you through the settings. If it had been working then stopped most likely just one setting has changed; the two things I would look at first is the password for the folder you are scanning to and and IP/Host Name of the computer you are scanning to.
Does your Domain require you to change your password on a regular bases? If so then the password set in the copier to access the folder on the computer may have changed and the new password needs to be set in the copier.
Also the person that setup the scanning originally may have set it to scan to the IP address of the computer you are scanning to but if the computer is setup for a dynamic IP address the IP will change from time to time and then the copier will not be able to find the computer you are scanning to. Change the IP that the copier is set to scan to, to the Host Name of the computer you are scanning to and that will no longer be an issue.
The Scan to SMB setup guide goes over these settings.
You can also call Kyocera's free help desk Monday - Friday 9 am - 6 pm EST at: 1-800-255-6482.
Dec 20, 2010 | Kyocera Km-3060 Mfp Copier Copy Machine...
Hi, I have Canon Pixma MP270. IS it possible to scan photo negatives and change to colour prints. thanks. Blair
A multi-purpose printer scanner cannot scan negatives or slides.
You need a slide scanner or a flatbed scanner that is capable of scanning negatives and slides. Not all flatbed scanners are capable of scanning slides and negatives.
Sep 27, 2010 | Computers & Internet
How can i hook up the scanner?
Hook the network cable to your scanner nec card on the machines, note that this machine has two nec cards, one for printer and one for scanner.
after that Go to the setting and under setting/Scanner Default create and ip address for the scanner. after you done from that go to the computer browser, type in the ip address, you can choose scan to smb or pc.
Scan to smb needs shard folder but scan to pc needs to run software on your computer on your pc.
Setup the sender list which you need to fill only the ip address of the machine as sender.
Go to destination setup the ip address of the computer you scanning to, the path is the shared folder name, and the user name and password of your computer and you good to go.
To make it easy for you, Provide me your email and i will attach the scanning manual to help you setup it correctly and you can always get back to me in any question.
Best Regards
Kyocer/copystar Expert
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jul 13, 2010 | Kyocera Copystar 221 Black and White...
My Visioneer 8650 flatbed scanner with auto document feed gives a message when I try to scan a document, telling me to move the switch on the bottom from the "locked" to "unlocked" position. The lock is...
Actually a very common problem. Try the following:
1. Power down then re-power up the scanner.
2. Try slightly moving scanner. Sometimes a small change works to fix.
3. Change one of your scan setting to flatbed scan (not adf). Do a test scan under this setting. This will usually kick start scanner unit to unlock.
4. Last resort, by does also work...give it a medium slap on the side, sometimes unjams the scanner light.
5. Super last resort, power down over night, it almost always works the next day. (could be that lock up is heat related to scan lamp, dont know but just a guess).
Excellent scanner, so worth the effort to try these fixes.
May 22, 2009 | Office Equipment & Supplies
Acer (BenQ) 620 scanner cannot scan transparency
Can you put some backing on the transparency and scan it like a regular item?
May 05, 2017 | AcerScan 620PT Flatbed Scanner
Scanner
is your scanner, by chance plugged into a power strip?
Aug 13, 2008 | HP Photosmart 3310 Printer
HP LaserJet 3050 All-In-One Printer Logo
320 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
