Question about Glyph GT 050Q Hard Drive
Glyph drive wont boot
I have the GT050Q 250GB Glyph drive and my mac froze the other day with the glyph attached to it, so I had to do a manual shut down on the computer. and now the glyph drive won't mount. I tried a repair disk on it and a verify disk - both of which failed.
any tips to get it running again?
thanks!
  • jflmarketing Dec 04, 2008
    A similar thing happened to me. We have this exact Glyph drive attached to our Mac Mini file server. I was working on my iMac client in Quark when the app "hung" (spinning beach ball) and I thought it was Quark. I had to manually shut down the computer as nothing else worked. When I rebooted and my computer tried to mount the partitioned volumes from the Glyph, it was a no go.
    I rebooted the file server, and the Glyph volumes SLOWLY appeared and everything seemed OK, BUT when I was back in Quark and I tried to open a file on the drive, the app hung again and I had to manually shut down my computer once more.
    So, I shut down the Glyph and Mac Mini (our file server config) and then powered them both back on, but now the Glyph won't mount.
    I thought these drives were supposed to be reliable and rugged. They include with the drive a heavy duty carrying case, and the metal front and casing gives it the appearance of a military-like construction. But this thing has never moved from where it was originally placed in an office environment.
    I guess I'll be venting to Glyph in an email...I certainly won't be recommending this drive to anyone looking for a durable, quality external drive.
  • lukeka Jan 29, 2009
    This is my same problem. Any solutions?
You could try a program like disk warrior or disk rescue, or you could try giving Glyph a call, they have pretty good warranty coverage.
Posted on Jan 30, 2009
Help! Glyph PortaGig 50 won't show up!!
Control Panel, Computer Management, Disk Management. Check that your Glyph is present. If it is present, does it have a drive letter assigned? If not Right Click and Assign Drive Letter.
If drive not present you should check power and data connections.
Dec 16, 2013 | Glyph PortaGig 50 External USB 20 Hard...
My glyph harddrive dont show up on my mac why?
If the hard drive was formatted on a PC computer in NTFS file format then the MAC will not recognise this hard drive.
If you want to transfer data between the PC and MAC then you need to format the hard drive with a PC in FAT32 file format. The MAC can read and write to a FAT32 formatted hard drive
Aug 08, 2012 | Glyph GT 050Q Hard Drive
My glyph gt050q wont load up. the computer wont recognize it. im running mac 10.6.7.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 24, 2011 | Glyph GT 050Q Hard Drive
PC won't see my glyph drive after I have installed Mac Drive 8
Take it back to where you bought it, and exercise the warranty, to get it replaced or repaired.
May 07, 2010 | Glyph GT 050Q Hard Drive
My computer doesn't detect my Glyph hard drive.
Ok mac and oc have two different file systems There fat32 and i forget the refernce for mac they do not see each other But you can ge6t a driver and format the system so it will work to your benefites for get a software drive converter
Oct 18, 2009 | Computers & Internet
My glyph is not loading and i did nothing wrong or weird to it, i want to smash it now!
Did you format the Glyph tabletop harddrive? If you didn't format it, it won't work.
Your Operating System is not stated, so let me give you an example using Windows XP. (Home or Pro doesn't matter)
Power cord plugged into the Glyph harddrive, and plugged into a surge protector, 6-pin Firewire cable, or 9-pin Firewire cable from Glyph to computer plugged in, Glyph power turned on, computer on, Windows loaded,
1.Left-click on Start, then Right-click on My Computer. Left-click on Manage, in the small fly-out menu.
2.In the Computer Management window, under Storage, click on Disk Management. The Write Signature wizard will pop up.
3.Use the wizard to write a signature to the new drive. The drive must be named. Name it what you want. (Drive 2; My Drive; Storage 2: Your name;
whatever you wish)
This drive must be named, or Windows won't be able to find it.
4.Now I suggest just making one partition, and it will be the Primary partition. Do this by selecting the Maximum Size. (Partitioning: Think of your harddrive as a large room. A Partition is a wall, dividing the room into two rooms. This time you won't be dividing the room. You will use the whole room. 250 GigaBytes of it) Choose -> NTFS.
Follow the instructions, let it format the harddrive.
You should be good to go now.
I have added this link, to a PDF file download of the
-> Glyph GT 050Q Quick Guide <-
http://www.glyphtech.com/docs/610021%20GT%20050Q%20Quick%20Guide.pdf
Jun 05, 2009 | Glyph GT 050Q (GT050Q1F250) 250 GB Hard...
My computer does not show glyph drive aftwer its connected
I had not created even a primary partition for my Glyph drive which I needed to do. So I created a new partition and seleected the maximum size for it which was all 500GB of the drive, since I dont want any real divisions of the drive; then I selected quick format. This is actually on the Glyphtech.com questions on how to format the drive, it will telll you about this step of creating a primary partition (or even more partitions if you want them).
Feb 19, 2009 | Glyph GT 050Q (GT050Q1F250) 250 GB Hard...
My glyph is not seen on my mac
If the drive is connected via firewire, power the drive. If the drive powers and you can place your hand on it and feel it "spinning", and still it does not mount. Try a different FW cable. If still no mounting action, place your ear on the drive to hear any grinding or clicking. If the drive sounds to be operating normal, open disk utility.. Hard drive/Applications/Utilities/Disk Utility The drive should appear in the left pane under your computers hard drive. You should see the button to MOUNT it on the top right. Hope this works
Oct 01, 2007 | Glyph GT 050Q 400 GB FireWire 400 (1394a)...
Glyph GT 050Q Hard Drive Logo
1,268 people viewed this question
Top Glyph Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Glyph Computer and Internet Expert? Answer questions, earn points and help others
