Question about GE Profile Harmony DPGT750EC Electric Dryer
GE Profile Harmony Dryer not heating
Repairman came out and replaced a coil thermostat - when he did the main board started making a burning smell and the repair said it now needed a new board that cost over $300.00 and by the time it gets fixed I will have over $550.00 in repairs.
I had the same problem, make sure the problem is no with the electric cord itself. My repairman told me he has seen a problem with the wires that connect the cord to the board not being tight enough, they short out and literally can catch on fire. He fixed mine for free but told me that this problem can show up six years after you have your dryer. I've had mine for three. The board was fine.
Posted on Nov 20, 2008
Bought an LG flat screen 2 yrs. Ago smells like burning plastic. Help!!
Burning smell is not good. Get it to a repairman, Too little info, could be anything cheap to major
Mar 22, 2015 | LG Televison & Video
I have a LG front load dryer. We smelled a burning smell. Now the dryer will not power on but the inside light works and the tub turns ! Could this be the thermostats ??
Need to trace the location of the burning smell and if this points to the main power supply or board then an examination will show up the damaged part, it could be a mains filter capacitor or a surge protector.
Dec 31, 2012 | Washing Machines
My fridge compressor stopped working. After checking the main control board I found a burnt transformer.I replaced it with a new board. It still did not work. So I checked the cooling coil and found a...
try to check your compressor resistance using ommeter or connect one test prod to terminal of compressor and one test prod to the body of your ref, if the pointer move or you read resistance it means your compressor burn out need replacement. or try to check your over load protector may be it damage.try to replace. the terminal of compressor is 1.2.3.connect the one test prod to 1&2 then read resistance then 2&3 then 1&3 these 3 terminal have different resistance these means your comp. is good.if good try to look fuses if damage replace it. observe unit. check your voltage supply may be it is higher than the rated voltage of your ref cause of burn out of your main board. or inspect the main board possible water leak the got wet the pcb boaerd
Feb 17, 2011 | GE Refrigerators
My daughter has a 3 1/2 year old dryer that just stopped heating up...any suggestions? and ballpark range of what it would cost to repair...thank-you
It will all depend on what is wrong to be able to judge the cost of the repair.
If your going to attempt repair or call a repairman.
Anyway I will give you some things to check
Please rate me
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Jan 01, 2011 | Frigidaire Dryers
We have a dryer that is 4 1/2 years old and the cloths are now taking a couple of hours to dry. I checked the lint fiter outside and is is not blocked and when the dryer is running the inside is not...
You should look to repair this problem, it will be cheaper than a new dryer...He is what I recommend you do to check your dryer...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
For video and pictures on how to replace the element go to the following website:
Dec 07, 2010 | Whirlpool Dryers
My dishwasher won't drain. Repair man is telling me the motor's burned out. Does this sound right?
Chance are there. If repair man says motor is burnt, he can always show you the motor. You can easily smell the burnt smell.
Let him replace the motor and collect the old motor. that is the only way you can make sure. Hope the repairman has checked all the the other points. Before replacing the motor, find out the reasons for motor getting burnt! No water seepage into the coil, no high voltage in your area etc.
Sep 17, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Have a GE GSS22KGMA side by side. Fridge gets warm at the top
Hi and welcome to FixYa. I am Kelly
I am going to paste part of your text and then reply:
Your text:
Repairman came back and replaced a small round part at the top of the evaporator (resistor??) <
{ That was the termostat}
I just read that the problem could be the defrost thermostat..
He already replaced it.
I hate to say it but is sounds like your in repairman hades.
So far I see 1. a new mother board, 2. new defrost thermostat and 3. new defrost heater element. (other than wiring that is everything in the circuit)
Either one of the 3 NEW parts is bad or...there is a partially broken wire in the circuit.
Hopefully this helps you understand. ( I know it does not fix your uint)
Thanks for using FixYa.
Kelly
P.s your words again:
one would expect this to be remedied.
You got that right!
Feb 11, 2010 | Refrigerators
Oven smokes and smells like burning plastic
This happened with my oven, happened twice to the same (newer) oven actually. The smell and smoke occurred both with the oven and with the use of burners on stove top. Turned out it was the main line cord which had a split. The first repair they replaced the thermol block and all the bolts holding it into place (for a total of 9 parts) the second time (about a year later) the repairman replaced the line cord and said that it probably should have been done along with the first repair. The smell coming from the oven before the repair was a toxic burning wire or burnt plastic smell. There was also smoke if the oven was left on long enough. The repairman said that the amount of heat to "cook" the connection on the line was at a fairly dangerous level. It was recommended to me by the fire inspector (who was in my unit for annual condo inspections) that it was unsafe and to have it repaired immediately. Hope this helps. Best of luck.
Oct 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag Neptune on/off button wont stay on
You have to investigate where the burning smell came from. Start at the timer and then check the main board. Also check the drain pump.
Oct 23, 2007 | Maytag MAH6500 Neptune Front Loading...
GE Profile Harmony DPGT750EC Electric Dryer Logo
173 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
