Goodmans ld3202 service menu code please - Televison & Video
Goodmans lcd tv service menu
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2014 | Polaroid TDA-03211C 32 in. LCD HDTV
Just stopped working.......
power supply fault . caps on power board bulged then that is the problem .. power caps are very cheap and easy to change if you can solder ? ps caps have + and - so only go one way
Dec 08, 2013 | Goodmans Televison & Video
Sky remote code for goodmans ld1940wd
Visit the site named 'Electro-help' for more details. Click this link. View it in Timeslide or Flipcard option, which can be selected from the drop down box menu by the Sidebar tag, at the top left corner of the display window. You can also click the Home tab to see the latest updates. It will make search easier. There are more than 1400 posts to different brand TVs till now. Setup proceedings and code list to different brand remote controls also included. Pull up older posts or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window
Dec 12, 2012 | Goodmans Televison & Video
Goodmans TD1540 remote code needed
Do you mean LD1540. If so try www.tvs-services.com
Jun 04, 2010 | Goodmans 15.4 in. LCD TV/DVD Combo
CANT FIND THE CODE TO TUNE IN MY SKY REMOTE,MY TV IS A GOODMANS LD3266D
On your sky remote press interactive-skyactive-help-set up my remote follow instructions. If your Model No not on list keep checking for updated info. If no joy then contact goodmans customer services.
Sep 16, 2009 | Goodmans Televison & Video
Unable to tune tv
next time you are moving a tv, make sure that
a tv is on a soft surface,
there is a dry joint on the card because of vibration onthe card.
take your tv to a w/shop for service.
that problem will be over. ok
Nov 23, 2008 | Goodmans 257NS 20" TV
SKY REMOTE CODE FOR GOODMANS GTVL19W17HD
The remote code is 1130 for this set.........using a v8 remote for HD box..... took 3 attempts to get it to work..... hope this helps....
Oct 12, 2008 | Televison & Video
Problem with my Goodmans 2065TS
Hi.
Sounds like your tv has gone in to service mode.
Try doing this (BUT DO NOT PRESS ANY OTHER BUTTONS)
  • Select pr. number 91
  • Adjust sharpness to minimum and exit all menus.
  • Quickly press the key sequence : RED - GREEN - menu
  • The software version is displayed beside the word Service, e.g. “ SERVICE V1.00A”.
  • To exit SERVICE menu press menu key or Std By key.
  • http://dysonmanuals.inc.io/
    Oct 26, 2007 | Goodmans 2065TS 20" TV
    Televison & Video Logo
    150 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
