V-sync offset problems on a 6200a
Hi
I installed a GeForce6200 256Mb(64bit) AGP on a compaq Evo D500.
I successfully install the card and drivers, then i unlocked the card using (Rivatuner)to get the all the pipelines working(it had a 6600 n43 GPU tweaked down).
I got that done ok, but started seeing artifacts on screen when running some computer games. :(
I tried to reset it back, but had forgotten which pipelines were originally disabled (duh2...)
i changed a setting then lost all screen output (!...) and coudn't get the card to work properly...
I reflashed the 6200 whilst fitted to another pc on dual screen.
After rebuilding the (D500), i chucked the 6200 back in and have got it working, but the screen is offset on the verticle, ie the bottom of the screen is in the middle and the top is under it.
the problem is on the bios setup on the card.
(imagine the old tv sets where you could adjust the v-sync)
what setting do i need to adjust(and to what value)?
help!...
  • 49 Answers
You need to flash to the origional bios. Obviously this is hardware related. For graphics cards v sync is software controlled, you have created a very hard to fix hardware problem.
Graphics cards are cheap now. YOu should be able to find a better replacement for even 30 =50 bucks on newegg.com
Posted on Nov 30, 2008
I am unable to install the network card of compaq evo... although i had tried to install driver from hp website of evo300 and evo500 series. please provide the solution for this issue.
There are 3 possible Ethernet adapters for your model.
3COM - Click For DownloadBroadcom - Click For DownloadIntel - Click For Download
Assuming you are using the card that came with the model and not a third party expansion card one of these three drivers should be the driver you require. Most commonly Broadcom is used by HP/Compaq systems so that is probably the best one to start with, Intel second, 3Com last.
Aug 27, 2010 | Compaq Evo D500 PC Desktop
I just bought a wireless card for my evo d500. when i instaled it, it had a few teeth in the slot left over (the new card did not fill all of them) when i turn on the comp., the keyboard is locked up, no...
You dont have the correct card in your computer. You may have a PCI card and a PCI II slot or the otherway around. There should be no extra teeth nor extra holes.
Remove the card and get the proper one.
Oct 25, 2009 | Compaq Evo D500 PC Desktop
Problem with my GeForce 6200a graphic card
the driver cause this so go to the below link and download the driver, befour installation go to ur contro panel and remove ur old driver then restart,
then install the new driver and reboot again,
this should solve the problem
link :
http://www.nvidia.com/content/DriverDownload/download_confirmation.asp?kw=&url=http://us.download.nvidia.com/Windows/181.22/181.22_geforce_winxp_32bit_english_whql.exe
Feb 01, 2009 | EliteGroup Computers & Internet
My cd of graphic gf 6200a is lose
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 25, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Compaq EVO 510 CMT
Accourding to other users that own the 510CMT, once the AGP card has been installed it automatically disables the onboard graphics card. http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do?prodSeriesId=316510&prodTypeId=12454&threadId=1050434&admit=109447627+1213753294488+28353475
From reading post from the link above, the EVO can run only a 4x 1.5v AGP video card and it's picky about this. So if you have an AGP card & it runs both 8x & 4x speed chances it wil not function in the EVO.
Here is a list of AGP 1.5v 4x cards that should function in the EVO:
http://www.google.com/products?q=NVIDIA+GeForce2+AGP+2x+4x+64MB+1.5v+only&btnG=Search+Products&hl=en&show=dd
Good Luck!
Mike
Jun 18, 2008 | Compaq (283983-001) Motherboard
Ethernet Drivers for Compaq Evo for XP
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=998
This should work.
And just to add that your system specs are really old and you should think about upgrading. 128 mb ram upgradable to 2 gigs.
Integrated 4x agp graphics...you should be able to install a new agp graphics card.
Or you should buy a new computer if you dont know how to build your own which can be tricky and expensive if you cant reuse many parts.
Jun 12, 2008 | Compaq Evo D310v PC Desktop
Installing a Dell RADEON 7500 AGP video card into a Compaq Evo SFF
Did you remove the previous video cards drivers from the control panel? The Catalyst Control Center requires Microsoft’s .NET Framework version 2.0. To remove what might have installed or your old ATI software run this uninstaller for Radeon. Download here:
http://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=1447
Try your install again.
Dec 14, 2007 | Dell RADEON 7500 AGP Graphic Card
Graphics card upgrade for Compaq Evo D500
A NVIDIA GeForce 6200 or similar will fit into the compaq slimline case. You need to get the slimline model, then modify the steel bracket to get it to fit. This is what iv'e done to a EVO (P4 1.8 GHZ)and
Sep 20, 2007 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
