Question about NEC MultiSync FE1250 22" CRT Monitor
Top half of screen is blank
My Toshiba Satellite 1555 screen has the top half missing (out of sync, as there are many vertical lines). External monitor works OK. Help
  • 188 Answers
SOURCE: Vertical distortion
With extreme care I have used a non-conductive tool, like the back end of a screw driver and flexed the circuit baord on a TV and eventually traced the problem to a cracked solder joint near the high voltage transformer. Slightly tapping on the tops of capacitors using the above method may also help. Working without a schematic is tough.
Posted on Sep 20, 2008
0 characters
1 Points
My Problem w/ my Toshiba Satellite P105-S9337 model no. PSPAGU - OOJOOV is it has a strip of white line vertical on the screen and it's about 1" thick? is their a way I can fix this problem?
Connect an external monitor to the VGA port on the computer. If that display is correct, then it's probably the LCD screen on your laptop that is damaged.
Find a computer-store. They may have "pre-owned" LCD screens the same size, for about $100.
A "brand-new" LCD screen is at least $200.
Replacing the LCD screen is *NOT* something that *YOU* can fix, unless you're a qualified technician.
Jun 15, 2010 | Toshiba Satellite 1105 Series 14.1" Flat...
Vertical lines in the monitor
Vertical lines from the top to the bottom of the screen are due to failing T-CON board (part of the LCD panel assembly). You can try reseating the ribbon cable attached to the T-CON board, otherwise new screen will be needed, these failures are due to cheaply made screen by company such as Chi Mei. It willget worst with more lines.
Jun 04, 2010 | Acer AL1715 17" LCD Monitor
Vertical lines on laptop monitor
This would need a screen replacement
Lots of people do this themselves
Ebay is a good source for laptop parts most of which are NEW
Aug 26, 2009 | Computer Monitors
Laptop monitor have vertical lines apearing out of nowhere...
LCD needs to be replaced.
Common problem called "Tab separation".
Jan 10, 2009 | Toshiba 14" LCD Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Vertical line top to bottom rightside of screen
hardware problem. please call manufacturer for warranty service
Nov 03, 2008 | Sony SDM-HS53/HT 15" Flat Panel LCD...
Vertical distortion
try to replace all capacitor in vertical section a leak capacitor can make your screen to shrink....
Sep 12, 2008 | NEC AccuSync 90 19 in.CRT Conventional...
NEC MultiSync FE1250 22" CRT Monitor Logo
Top NEC Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a NEC Computer Monitor Expert? Answer questions, earn points and help others
