Question about Frigidaire GLTF2940ES Front Load Washer
Loose tub when the tub spins itgoes clunk at the same spot every revolution.springs seem god
  • 370 Answers
Check the shocks under the tub. The shock mounts break frequently.
Posted on Nov 18, 2008
Tub is crooked, could a balancing spring come loose
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Feb 12, 2014 | Estate Washing Machines
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
I have a Kenmore washing machine model # 11020854990 which recently had a loud banging and knocking sounds during the final spin cycle. Now I notice the drum seems to have dropped down about an inch plus...
Could be a loose basket nut, or on the bottom tub support there are a few springs that help locate the tub. One of the springs could have come off or broke.
Nov 28, 2017 | Kenmore 24032\24036 Top Load Washer
Loud clunking, banging sound during the spin/drain cycle.
the make , model and year are missing but if it is a top loader unit , it indicates that the tub suspension bar motion absorbers have broken and need replacing
Sep 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Clunking noise and drum gets stuck
It sounds like your washer needs an overhaul . A new tub and bearings it's a big job with a big price tag.
Jul 02, 2010 | Hotpoint WMA32 Front Load Washer
Shakes during spin cycle like off balance but its not , also makes a loud clunking sound wont trip out the whole tub assembly seems loose
it probably is lose sounds like the balance springs on the bottom of the tub either come off? or are broken
Jan 14, 2010 | Washing Machines
I have a loud clunking noise after my maytag empties the water, it seems to be getting worse. The model is a centennial top loader. IT is getting to be annoying. Any help will be appreciated. Thanks
Check the springs or straps that are connected to the wash tub. They keep the tub centered in the machine; if one is broken loose the tub will bang against the sides of the machine.
Sep 12, 2009 | Washing Machines
Excessive lateral travel of tub in spin cycle
there are springs that keep tub centered.also some small glides that can wear.most common prop.spring.most models can look thru bottem .the spring that fails most is towards the back,left rear,goes from washer to body.check that out God bless,tom
Jan 03, 2009 | Whirlpool LXR6432JQ Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
56 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
