Question about Canon CanoScan LiDE 30 Flatbed Scanner
CanoScanner LIDE 30 When I hit the scan,copy, file,etc. I get the following: "unable to locate twain source" No functions, how can I correct this?
  • mambosnake Nov 22, 2008
    exactly the same. where do I find the TWAIN source?
Unable open twain source please
This is an issue with the Driver Installation, Get the drivers Uninstall and reinstalled from the CD.
May 11, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
Give this a try (found online):
Download Irfanview:
Open the main app "i_view32.exe"
With the scanner hooked up, click onto the "file" (tab)
Click "Select TWAIN Source .." and select your scanner in the source box (if it is listed, the driver is functioning)
Click file (tab) then "Acquire"
Hope this helps.
Sep 15, 2011 | Canon CanoScan LiDE 60 Flatbed Scanner
When i try to scan i get this message: unable to open TWAIN source Please check connection then re-start Toolbox the connections are tight
Driver mismatch - the driver of the scanner has forgotten the location of the TWAIN driver because another software has been using it lately. Follow this
Feb 20, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
I have HP Officejet J3680 All in one I wanted to scan a document but it is saying there is not option..
canning functionality from the LJ3380 and CLJ2840 series All-in-One devices may not function until the correct Twain Data Source is selected by the user. This can be done by attempting to scan from the foundation scan executable "hppscan2.exe ".
  • For the LJ3380 series this is located in C:\Program Files\Hewlett-Packard\LJ3015_LJ3020_LJ3030_LJ3380->hppscan2.exe
  • For the CLJ2840 this is found in C:\Program Files\HP\Digital Imaging\bin->hppscan2.exe
When the "hppscan2.exe " is launched from this location where it resides, a dialog box will open with a "Select Source " box listing the installed Twain scanning devices available. If this box is not seen, then there is only one Twain device installed. In some instances user input is needed to chose the "correct" Twain data source for scanning to be successful from the LJ3380 and CLJ2840 series devices. If the incorrect Twain data source is selected- an error "Cannot initialize device " will be seen.
Oct 27, 2010 | HP J3680 Officejet All In One Printer
CanoScan LiDE 30 Flatbed Scanner: When I click the scan button it says, "Cannot find...
Make sure the USB cable is properly connected at both ends. Close the Canoscan software and then reopen it and try again.
May 18, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
Can't copy or scan on canoscan lide 25
You need to install the software drivers You need BOTH programs installed on your PC, Toolbox & Scangear. Also use the driver remover first. Then unplug scanner, reboot, install Scangear first, and toolbox second, then reboot, when at desktop next time, plug in the Scanner. Hopefully it should be all good. Read the Help file.
Feb 17, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Canoscan Lide 30 - want to use on laptop running XP Pro
Did you restart your computer after you downloaded your drivers and software? Did you select the correct operating system? Make sure the USB cable is plugged into the computer and the scanner...Open the toolbox and click scan or save and check to see if the scanner makes any noise or lights up...If you are using Windows XP then make sure you have downloaded the "TWAIN" driver and the "WIA" driver (two seperate downloads)
Jun 30, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Unable to select TWAIN source
tried uninstallin and installin canon scanner drivers..nothing works..still seeing unable to select twian source..
so i tried an we go..
on vista 64 os/vista any Start>All programs>Windows fax and scan
next click new scan on top and that got me going.
some say there are issues with the way usb talks to old scanners with new operating systems like mine (vista 64). hope it helps until you find the actual cure.
Jun 24, 2008 | Canon LIDE20 Flatbed Scanner
Lock Switch and IF cable
Mine was doing the same thing. When I get on the program, before I click "acquire" to preview and scan, I click OFF the toolbox and then everything seems to be okay and I can go ahead and scan.
Nov 27, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan LiDE 30 Flatbed Scanner Logo
375 people viewed this question
old marine
old marine
