Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
I need to send a mass fax once a week
I need to store a lot of fax numbers in the machine and once a week send a mass fax to all of them. What's the best way of doing this?
  • 284 Answers
You need to program the numbers you want to fax in the speed dials and abbr numbers, then you can use a program key to select them all.
function-7-2-start [this is where you program your numbers]
function-7-3-start-1-start- then push your p key enter a name then hit start then select your phone numbers
Posted on Nov 17, 2008
Insert the fax. Prepare the documents you need to fax. Place the original paperwork face down with the top edge first in the Automatic Document Feeder.Set up the cover page. Press the "Menu" button, and then press "2," "2," and "8." When "Next Fax Only" appears press the "Set" button. Use the arrows to select "ON" and then press "Set."Select a cover page comment. The comments available for the fax receiver to view include, "Please call," "Confidential," and "Urgent." Use the arrows to select a comment and then press the "Set" button. Input the number of pages you are sending and then press "Set" again.Enter the phone number. You can store phone numbers in your system under the one touch dial or speed dial options. Use One Touch, the key pad, speed dial, or search to enter the phone number you would like to send your fax to.Send the fax. Once the document is inserted, the cover page is set, and the phone number is entered press the "Fax Start" button located in the bottom right corner of the control panel. Your fax machine will then dial the number and proceed with sending your documents
Apr 16, 2011 | Computers & Internet
How to send a fax
1)place the document or paper which you want to send in the fax machine feeder facing the direction the machine specifies
2)Now use the number pad in the machine and type the number to whom you need to send the letter
3)once you have finished entering the number press the send key thats is in the number pad
4)once your page is send successfully you will get a confirmation print in your machine
I hope this will help you If it does do rate this answer
Thanks for using fixya
Mar 15, 2011 | Office Equipment & Supplies
Just bought brother fax 1960c My dsl for the
Look on Page 101, "Phone line interference" and be sure compatibility is set for "basic." See if this works.
Jan 13, 2010 | Brother FAX-1960C
How do i stop the phone going through to the fax machine if you dont answer it after 5 rings, we have the same phone and fax number and if you dont get to the phone in time it will go to the fax. as we are...
Go to an electronics store (Radio Shack) and buy a spliter. They sell a spliter that recognizes the call as a fax or phone call and sends signal to proper line. When you hook up the unit you will have your line in, then the outputs will be marked one to the fax and one to your phone. Once you install this your problem will be solved. You only have to hook one at at the fax machine not at all phone jacks.
Oct 15, 2009 | HP OfficeJet 4255 All-In-One InkJet...
How to save numbers
Your machine can store up to 30 numbers. To store numbers, use the following process:
  1. Press functioni button once
  2. Press right arrow > once
  3. Assign a two digit speed dial number or press the right arrow (machine will suggest a 2 digit speed dial number
  4. Enter the fax number (use speaker button if a mistake is made to clear)
  5. Press Start/Memory button
  6. Go to Page 28 in user manual
At this point, there's a chart for entering names for the fax numbers which can be found in the owners manual at this link:
After the name has been entered, press Start/Memory button to Store and press Stop button to leave the process.
Best of luck and hope I helped.
Jun 16, 2009 | Sharp UX-P115 Plain Paper Thermal transfer...
Just a question
How do you change the number on the HP office jet all in one Fax machine.
Dec 19, 2008 | HP FAX 1250 Fax Machine (Black)
I need to store a lot of fax numbers and every monday send out a mass fax to all of these numbers. How do I do this?
Press Function 72
Put the numbers in one touch positions 01...02...03...etc.
Press Function 73
Choose GROUP
Press PROGRAM 1 on soft pad and name it. Press SET
Add the one touch numbers into PROGRAM 1 by pressing their numbers on the soft touch pad.
01...02...03...etc. SET....STOP
Nov 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Faxing to several numbers
Sending Broadcasting Faxes:
Using the BROADCASTING BUTTON on the control panel you can use the broadcasting fax feature. 1. Load the document(s) face down into the ADF. 2. Adjust the document resolution to suit your fax needs.Press BROADCASTING on the control panel.4. Enter the number of the remote machine using the number keypad. 5. Press enter to confirm the number.The display ask you to enter another fax number to send the document. 6. To enter more fax numbers, press 1 to select "YES" and repeat steps 4 and 5. You can add up to 10 destinations. NOTE: You cannot use group dial numbers for another fax number. 7. When you finish entering fax numbers, press 2 to select "NO" at a "ANOTHER NO" prompt.
The document is scanned into memory before transmission. The display shows the memory capacity and the number of pages being stored in the memory.
The machine begins sending the document in order of the numbers you entered..Hope this helps
Oct 08, 2008 | Samsung SF-560 Plain Paper Laser Fax
Multiple faxes
you can send it seperat only
Sep 19, 2007 | Canon LaserClass 2050 Plain Paper Fax
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
98 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
