Check the resolution settings, right click on the desktop if you are using vista then click on personalize and go to display settings and make sure that it is set to your desired settings.
If using XP then right click the desk top and go to properties then check your display settings from there.
I hope this helps
have you checked the refresh rate?
that is still very strange, once you have done that run a dxdiag to make sure that you are not having any graphics errors,
go to start>run and type in dxdiag to open directx diagnosis program and run the display checks
if using vista go to Start>accessories>run
sorry that you found my advise as inappropriate
I tried that as well didnt help
I will delete and create profile again bcoz its doing this only to one profile.
