Question about Ariston Technologies AW125NA 13 lbs. Load Capacity Washer
Ariston washing machine
No power on light or power to machine plug is fine as is supply
  • 734 Answers
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Posted on Dec 03, 2008
Why my washing machine unable to switch on?
If there are no lights, check the fuse in the plug.
If the machine comes on but the drum does not move, the motor control circuit board probably has a burnt connection or bad joint. This may also be the cause of the fuse blowing.
Jun 05, 2014 | Ariston Technologies Ariston AWD12 Front...
Ariston a1435
Does it work before? Try reset the machine... 1.0 Turn off the machine. 2.0 remove the power supply from the main supply. Leave the machine without any connection for about 15 minutes. try again?
Sep 14, 2007 | Washing Machines
Ariston Washer not running Programme
It sounds as if the brushes in the motor have worn,when the motor stops it wont go through the program,try turning the ddial around to spin to check the motor
Mar 07, 2014 | Washing Machines
Ariston LI640A 2nd and 4th light flashing
Usually this is a sign that you should call the repairman. However, I had a flashing light once because I made the mistake of trying to use my Ariston without turning on the water to it. I unplugged it from the power and let it sit for about ten seconds. When I plugged it back in, the flashing light was gone. I am not sure if this will help you or not but it is certainly worth the try.
Nov 15, 2013 | Ariston Technologies LI640S Dishwasher
Ariston a1600wd wont turn on
Before you change fuses, do you have an internal fuse board or RCD system in your home? Sometimes, an individual RCD can trip out, locking off sockets. Some sockets are individually set up for up and downstairs in a house, or different rooms. If you have a board or RCDs, check them out :)
Nov 18, 2017 | Ariston Technologies Washing Machines
My machine has all the lights flashing but not brightly and won't do anything. I've switched it off overnight and it's still doing it! Any ideas?
your voltage migh gone down, your supply of electricty might not have enough power, try to unplug other appliances to your house , and let only the washing machine be plug on, if this work, it means that your eletric current is under voltage or you have a voltage drop on your electric supply
Oct 31, 2009 | Ariston Technologies Washing Machines
ARISTON WASHING MACHINE DOOR PROBLEM SO ON/OFF BUTTON DOESNT WORK
Well it depends on how old your machine is, if eveything else is fine then replace it. The cost will vary depending where you buy your part from. It could cost but worth it if machine is reliable. try
www.lpdlpd.co.uk
Aug 09, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Washer dryer won't power up
Worn brushes on motor can cause machine to seem dead. No voltage trough motor.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Ariston Washing machine A1636 - Flashing lights
what 2 lights are flashing each light that flashes gives a differant fault code . Get back to me
Jun 20, 2007 | Ariston Technologies AW149NA Washer
Washing Machines Logo
395 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
