Water doesn't advance into the filter, therefore the coffee in the filter doesn't get brewed. Also the machine turns itself off before brewing is finished and I have manually turn it back on. This can happen two to three times while brewing one pot of coffee. Coffee doesn't stay very hot.
I went to the Krupsonlinestore that you recommended but did not find the plastic part for holding...
(More)
I went to the Krupsonlinestore that you recommended but did not find the plastic part for holding the screw for the handle for the Krups Aroma Control 229 Coffee Maker carafe. Is there anywhere else to find it?
The coffee maker will no longer power on. It was working fine one day and the next day nothing. Its...
(More)
The coffee maker will no longer power on. It was working fine one day and the next day nothing. Its not the outlet so assume its either a circuit breaker in the machine or the switch went bad. I see I can order both but would like to just buy what I need. Thoughts
