Question about Compaq Computers & Internet
My v6133eu laptop will not switch on
The external power supply is working
Thanks for this solution
Posted on Feb 28, 2009
  • 458 Answers
Possible DC Jack Needs Replacement..... If You Pull Your Battery out and Try To Power On Using The AC Adapter alone... If No Power Lights Come On, No Fans Spin Etc... You Need A New DC Jack..
Posted on Nov 17, 2008
!!!no reaction on plugging the ac adaptor.!!!
Sound like the LCD screen's inverter is causing an short/overload and the power adapter is shutting down (thermal cutout).
Remove the LCD screen and connect an external monitor, power up the external monitor first and the boot up the laptop. The video should automatically on the external monitor. If the display on the external monitor is OK then the fault could be the inverter which is located at the bottom of the LCD screen between the hinges.
LCD screens and Inverters for your laptop maybe available from this WEB site.www.lcdparts.net
Apr 13, 2012 | Toshiba satellite c660
Have a 1 tb buffalo external hd. worked great had it for back up. I unplugged it to move my computer. when I plugged it back in, there was no green light no power to the drive. check voltage and the power...
try to test it on other computer or laptop... if the unit are still exist maybe your problem would be the external drive..there are no switch button on it, because most of the switches are located on the adapter, the only testing you could do is to test it to other unit..If the external drive are ok once after you test from other PC's, then might as well check your USB port by plugging-in to other port...or try to use other power supply on your computer, co'z sometimes the supply can no longer supplied any voltage coming from your external drive once it plug-in..
Aug 20, 2011 | Buffalo Technology DriveStation Axis 1 TB...
My Hard drive was working fine until I uplugged it, have just tried to plug it back in and now my laptop won't recognise the drive, it can't find it. help?
Does the drive have its own power supply or does it get power from the laptop? If it gets power from the laptop, does it have a plug for an external supply? If it does, try plugging in an external power supply. Sometime the laptops can not supply enough power.
If the drive is working at all, you should feel some vibration and hear the drive spin up. Can you tell if the drive is spinning up?
Jul 01, 2011 | Computers & Internet
My Gateway M-6307 has a backlighting issue. The computer works but the screen is really dim. External output works, but dim on the LCD. I have switched LCDs from another Gateway laptop...same results. I've...
Have u tried replacing or trying a different power supply? Sometimes when a power supply is going bad will not put out the right voltage for the internal switch to kick up the brighter setting. Therefore it still thinks its on battery mode. Test the voltage from the supply and compare it to the recommended voltage gateway suggest for that laptop.
Jun 24, 2010 | Gateway M-6307 Notebook PC
MY toshiba satellite 2430 CAN NOT POWER UP. BUT IT ALL THE LIGHT IS ON WHEN I SWITCH ON THE DC POWER SUPPLY SWITCH. WHAT IS THE PROBLEM? HELP.
remove the battery and remove the power adaptor ... press and hold the power button in the ON position and count to 20.
attach the AC adaptor only and press the power button ...this should fix the issue ... then re connect the battery.
if this does not work then add a external monitor .. if it lights up then hit the
Fn + F5 keys
Display modes
Fn + This hot key cycles through the power-on
display mode options.
The display mode options are:
Built-in display panel only, Built-in display panel and
external monitor simultaneously, External monitor only.
Fn + This hot key cycles through the power-on display options.
The display modes are:
❖ Built-in display panel only
❖ Built-in display panel and external
❖ External monitor only
video device simultaneously
❖ External video device only
Oct 07, 2009 | Toshiba Satellite 2430 Notebook
Laptop intermittently works with battery
The adapter does not have a switch. When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
When you boot up the laptop with the adapter connected and check the power setting from the Control Panel and if it indicates it is on battery power, then either the adapter is faulty or the connector is not making proper electrical contact. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Replace the adapter if it is faulty.
May 06, 2009 | HP Pavilion zt1145 PC Notebook
URGENT! My computer doesn't switch on and Ihave a tight schedule.
PUSH And hold in your power switch for 15-30 seconds
Apr 08, 2009 | Computers & Internet
External hard drive wrong power supply was plugged in
The power circuits in the external hard drive enclosure may have burnt out or the fuse may have blown. Its unlikely your hard-disk is itself damaged.
You may remove the actual hard-disk from the enclosure and put it in another and access the data.
All the best!
Jan 29, 2009 | Computers & Internet
External hard drive
Yes, no problems, if the USB hard drive draws too much power you will need to attach an external power supply, usually the small laptop 21/2" drivers don't need external power supplies.
Jan 10, 2009 | Dell Latitude C610 Notebook
Simpletech 500 gig usb plug in hard drive
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
Feb 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
94 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
