In most film cameras, a battery is not necessary to manual advance film
using the lever. Your Canon AV-1 is no exception. I have owned two
cameras from the same group, the AE-1 and the Canon A-1. Neither
required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A",
otherwise the shutter won't release and the film lever won't work
correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Was this helpful?
Yes
No
Popular Solutions for Canon AV1 35mm SLR CAMERA
Canon AV1 35mm SLR CAMERA SPARES OR REPAIR 35mm Film Camera
Lens Cap Cover for a Canon Wide Converter WD-58 0.7 x 58 The Lens Cap Cover is approximately 80mm...
(More)
Lens Cap Cover for a Canon Wide Converter WD-58 0.7 x 58 The Lens Cap Cover is approximately 80mm where it pushes on to lens shield and approximately 6mm deep. Please supply price, availability & delivery time. Thanks Tony
i was just got a new battery for the canon av 1 and i swiched the dial to B and pressed the photo...
(More)
i was just got a new battery for the canon av 1 and i swiched the dial to B and pressed the photo button, and i heard a click. nothing happened so i took the lens off and the mirror inside was retracted up and there was this small orange plastic tube piece like it had snaped off
1 ) I had received an advice before, but it did not help.Please tell me how to install the web...
(More)
1 ) I had received an advice before, but it did not help.Please tell me how to install the web camera. 2 ) QHM 480 LM is my web camera and whenever i tried to install it shows that the quantum web camera ZS0211 hardware is installed and my web camera doesn't work, please show me the way.. 3 ) I could not remove some softwares, files or programs from add or remove in control panel even after formating or booting my system. Tell me how to remove the files.
>setupdll/setupdll.cpp(409)$7.0.100.1342@windows XP
