Question about Apple iPod MP3 Player
Connecting an ipod to a mondeo
I want to get an ipod for a 55 plate mondeo, however, i'm not sure if it is possible to connect one at all!! there is no socket on the face of the stereo but there is an 'aux' button. is it possiblr to connect from behind the stereo? what equipment is needed to do so?
  • 342 Answers
With an itrip you can sync it to a radio station and hear your ipod through many systems. Usually they range in price from 30-60 dollars but are awesome. I hella recommend it. No wires needed
Posted on Apr 24, 2009
Light not working .how to fix
try all this and fix it. God bless you
Hold switch on
Before delving into the guts of your iPod, check to make sure the hold switch isn't activated. If the hold switch is on, the iPod will ignore any input on the click wheel and refuse to do anything. If your iPod's problem isn't so easily solved, read on.
Drained/bad battery
If your iPod won't turn on, especially if it has not been used recently, you may simply have a drained battery. Plug your iPod into your computer or AC adapter and see if anything happens. Ideally your iPod will recognize it has been connected to a power source and charge its battery. If it will no longer charge, the battery must be replaced.
Bad display
It is possible that it appears nothing is happening because the display is bad. If you hold the iPod up to your ear you should be able to hear the hard drive spinning. If the iPod sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced
Bad logic board
If your iPod does nothing when plugged into a computer, the problem most likely lies in the logic board.
Bad click wheel connection
If the click wheel is not seated correctly, it is possible that the iPod will not boot. Be sure that the bar on the click wheel is completely flipped down to ensure a positive connection.
Jul 30, 2013 | Audio Players & Recorders
Mondeo wont start
Have the battery charged and checked for cca's. Make sure connections to battery are clean.. Last it could be a bad starter
Jan 28, 2010 | 2001 Ford Focus
Mondeo 55 plate starting problems when the engine is warm
Hi Warren,,
These cars are fitted with a Delphi common rail system that is known for various faults including yours, you need to have a sealed rail test done on the injectors as they are probably leaking off to much causing low pressure in the common rail,when the car is warm,they also suffer with injector code loss ,no reason they get confused this normally gives poor performance and high fuel consumption ,if the injectors are fine check the system for air leaks in the fuel supply pipes and check the leak off pipes for leaks,even the smallest leak can let air in,if the engine light has come on get the codes read ,
Darren DCS
Aug 12, 2009 | 2005 Ford Focus
My Video 55 player will not play my videos
You need to switch the video out seeting on the iPod, simple. It is located in Video/video settings/TV Out. Change the setting to "On". Problem solved. However, if you have an iPod that is less than 1 year old, nothing will work, iPod blocked this ability to change to "On" and is set on "Off" permanently.
Mar 04, 2009 | Sonic Impact Technologies Sonic Impact...
How to connect to ford mondeo
You can go two routes for this, wireless or cabled. Wireless is of course good because it has no cables but the sound quality is not that great - ok, but not great. So my suggestion is to go the cabled route which actuall ends up being neater anyway and gives pretty much 1:1 quality. There's plenty of people out there that creat adaptors and cables but check these guys out:
http://www.nexxia.co.uk/iPod_MP3_Adaptors/ford.htm
They range from about £50-100 - and doing a search on eBay for 'Ford iPod Adapter' comes up with similar devices at a similar cost.
All the best
Sean
PiDigital
Dec 26, 2008 | Apple iPod nano
Ipod vido out
Using the iPod AV Cable
Step 11Use the Apple iPod AV cable. This plugs into the RCA ports on your TV or VCR. This is by far the easiest method. Step 22Connect the AV cable into your iPod. Plug the small end into the iPod where the earbuds would go. Step 33Connect the red RCA plug. This goes into the right audio input of the television or VCR. The colors should match. Step 44Connect the white RCA plug. This plugs into the left audio input of your TV. Connect the yellow RCA plug. This goes into the video input of your TV. Step 55Begin playing a video on the iPod.
May 27, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MP3 Player Logo
218 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
