Question about iRiver iHP-140 MP3 Player
Stuck on read system files
When player is turned on start menu appears then read system files. it freezes on this screen for ever and won't turn off. tried reseting but the same thing happens over again.
  • sabba_r Jan 20, 2009
    when player is turned on start menu appears then read system files. it freezes on this screen for ever and won't turn off. tried reseting but the same thing happens over again.
I think your hard drive is dead. im not an expert but the same thing happened to me and i got it sorted with a new hard drive.
Posted on Apr 13, 2008
Player won`t read
turn console onto standby and leave a min
then hold button in till it beeps 3 times and release
then do this again it will beep 3 times last one being double quick beep
a menu should appear
click on the one that says files this will restore your lens reader
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Nextar ma852-801 mp3 freezing...reset?
Hi.
Welcome To Fixya Community.
Solution 1:
  • Try to Turn it ON/OFF(Reset).
If that isn't Working try This:
Solution 2:
  • You are going to upgrade the Firmware of your Mp3 Player in order to perform that follow these Steps:
  • Installation of the Upgrade Tool:
  1. Download the Upgrade Tool application (the download link is in the bottom of this Solution) to your computer.Double click the application.Follow the instructions shown on the screen to complete the installation.Firmware Upgrade:Note: All the existing files in the player will be erased while upgrading,please make a copy of your files before doing this.Turn on MA852-801 player. Press and hold the MENU button todisplay the main menu. Select “Settings” → “System” →“Upgrade” and press the MENU button to confirm. Select “Yes”and then connect the device to a computer via USB interface once you see the following window:
2. Select ”Program files” 􀃆 ”Firmware Update” from the Start
menu or double click the “Firmware Update” icon on the
desktop. You will see the following window shown on the
screen:
6fc021c.jpg***************************************************************************************
3. Click Open button, and specify the upgrading firmware with
the extension “ .rfw ” (Please download the firmware from
Nextar website named MA852-801 – updated firmware.rfw).
Click Update button to start upgrading.
Note: This process may take about 2 minutes depending on the
computer system you use. Please don’t disconnect while upgrading,
it may cause serious damage to the player.
4. Once it shows "Firmware update successful"wording in
“Update Info” window, then click Exit button to finish
upgrading.
*************************************************************************************(5) 5. Safely remove the player from the PC.
6. Turn on the player. Please wait about 20 seconds for the
player to automatically initialize settings.
Downloads:
Upgrade Tool.
Firmware File.
Additional Help:
Nextar Ma852-801 Mp3 Player Manual Guide.
please don't hesitate asking me if you need any Further Info.
Thank You For Using Fixya.
Good Luck.
Nov 04, 2009 | Audio Players & Recorders
Sana e280 frozen screen reads Refresh Database
put the player in recovery mode by placing the hold slide button at the top of the player so that the red showes, held down the record button while turning on the player. upon connecting the USB cable the unit will go into the recover mode. Go to my computer and look for the drive which states "16MB Format" and copy the firmware files into it. Disconecting the cable after the files are copied will cause the player to reload the firmware. The player will restart and then shut off because of the Hold button position. Slide the Hold button back into normal mode and push the menu button to restart. The unit will power up and display the language settings. I went to the settings menu and changed the player USB setting to USC. I then placed the player in recovery mode again and went to the MY Computer again and set window to show hidden files. This allowes windows to see the database drive. I then ran chkdsk on the database drive which found a lot of crossed linked files. This then allowed me to delete all the files in the database. Upon comming out of the recovery mode the unit restarted normaly.
You can get the firmware at this site. http://mp3support.sandisk.com/firmware/e200/e200v101.02.18a.zip
Oct 11, 2008 | SanDisk Sansa E280 MP3 Player
Archos 605 WiFi stuck
Hey
I suffered the same problem as you, fortunately I fixed it after a lot of messing around.
First what you want to do is switch off the system completely. Once the power light is off, switch the system back on, once the LCD screen turns on, immediately press and hold down the YV/LCD screen for about 5 seconds, a white screen should appear.
You will have three options, click the second option, (i think it is repair) and connect the archos to the PC. This will allow you to transfer all your files to PC because you can access the harddrive.
Once you have taken all the files you want, turn the system off again. Then again, turn the system on, hold down the TV/LCD button for 5 seconds until the white screen appears. Choose the format option. This will take your archos back to factory settings. It took me a few goes to get it back to normal but once its done, you will be glad you put the effort in.
Now all there is to do is to take your files back across via cable and you should be done!
I hope that helped!
Aug 03, 2008 | Archos 605 WiFi Digital Media Player
Can u help pls
1) Hold the power button (slider) in the on position for about 15-20 seconds to force the player to turn off, if it's already on.
2) Hold the menu button down and simultaneously hold the power button (slider) to the on position.
3) Do not let go when the device turns on. You will then get a screen message in black and white that reads (with a typo):
WARRING !!!
NAND FLASH MEMORY INITIALIZE......
"WARRING !!!" will appear in red (and probably should read "WARNING". You will have the options of "No" and "Yes".
4) Choose "Yes" to re-format your device.
Jul 09, 2008 | Insignia Sport MP3 Player
Help fix this
WARRING !!!
NS-xV24 Insigna Pilot
WARRING !!!
Jun 24, 2008 | Insignia Pilot MP3 Player
Cant dectect the player
WARRING !!!
Feb 07, 2008 | Insignia NS-DV2G MP3 Player
Sanse e200 freezing up for no reason!!!
Hi. It seems like your player decided to throw a hissy fit by deciding to experience internal system errors. Best that you reset the firmware. Here's how: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Step 5: Enjoy using your Sansa E250, just like I do. (I love this player)
May 14, 2007 | SanDisk Sansa e250 MP3 Player
iRiver iHP-140 MP3 Player Logo
119 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
