Question about Olevia LT37HVS 37 in. LCD HDTV
Olevia 37 turning off for no particular reason
My set is less than two years old it is turning of after making a loud schreeching sound i have had the cable co out several times and they are stumped sometimes the set will work all day and at other times will come on for a few munites then shut down
  • KnightH Dec 07, 2008
    I agree that the main power supply is bad.  Did you ever find a solution?  My TV cuts out several times throughout the evening.  Sometimes one power reset will be all that it need, but other times I need to turn the tv on multiple times during one tv show.
  • Olevia Master
  • 5,568 Answers
I suspect that the main power supply is trying to self-destruct; what you describe could be the switching power supply struggling to stay up and running. It isn't the cable company's problem.
FYI: Olevia has declared bankruptcy so you may not be able to get any help from them.
Posted on Nov 23, 2008
My olevia 237-t11 turns off by its self and sometimes makes a loud screcheen noise
Sounds like either the main or display power supply is failing. Might consider a new TV. Parts could be found but it might be hard to find them.
Aug 28, 2014 | Olevia 237T 37 in. LCD TV
My 37 inch Olevia that is 3 or 4 years old is stuck on a very loud, so loud I have to turn it off, but I can't access the volume on the remote or on the TV, it is so weird! The remote does work to turn...
When you have strange problem like this, power supply module will be the first thing to check for steady DC. Since this company is no longer around and parts are getting hard to come by, the repair shop will not even try to do component level repair on it due to time consuming process and no schmatic available.
There may be not much you can do.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Olevia+LT37HV+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Olevia tv, no power
This the common problem for Olevia TV, open up the back cover, locate the power supply board, look for the electolytic capacitors top that is slightly domed, replace them, they usually 1 or 4 that is bad, buy your replacement's at Radio Shack
Jun 06, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Olevia tv
It sounds like a logic issue. The only way to fix it is by replacing the main board. If it is less than a year old, then it should be covered by the standard manufacture's warranty. Olevia has since gone out of business but I would still try to contact a representative to get it repaired under warranty.
Nov 08, 2009 | Televison & Video
Screehing noise when furnace is running
usuall a schreeching noise during blower opperation is bad berrings which would need to be replaced. Most unit warrentys for newer units cover five year parts and sometimes 10 for heat exchanger. But most do not cover labor. Or the blower may just be off balance and metals are rubbing. eaither way your proubly gonna need a tech. good luck
Mar 17, 2009 | Ingram GMS90904CXA Heater
Crackling noise
I think I have solved the problem. I dusted the tv completely. Then took the cable box and with a hair dryer in the cool setting blew out the interior circuits to try to remove all dust. Turned the set on no more crackling. Thanks for the posting.
Nov 14, 2008 | Olevia LT37HV 37 in. HD-Ready LCD...
OLEVIA 437-S11 Poped and wont come back on
I bet your power supply went bad, Same thing with mine. Got a new one on the way. Youl have to call Olevia direct, no aftermarket parts avl.
Sep 03, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Power problems
I have a 32'' olevia 232v hdtv. I had a similar problem where the tv stays on less and less as you use it longer and it gets warmer. I called customer service and they explained that its most likely a problem with it is doesnt have enough power to run well. They said turn the TV off, then hit the master turn off switch in the lower back of the tv, then unplug everything from the TV, then unplug everything from the wall. Then after 3 or 4 hours, plug all back in and try again. Then they said if i still have a problem, call customer service at 1 866 9 olevia
Sep 29, 2007 | Olevia LT37HVS 37 in. LCD HDTV
SHARP,PIERCING, ALARM LIKE NOISE COMING FROM TV
unhhok all the sources from the tv as to eliminate where it might be coming from, hook up one source at a time you might find the problem that way
Oct 20, 2006 | Olevia LT32HVM 32 in. LCD Television
Olevia LT37HVS 37 in. LCD HDTV Logo
134 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
