Question about HP Pavilion ze4365us Notebook
Computer never starts
Computer tries to powers up for 1 second then goes into a continuious reboot. Replaced the power adapter, and just oredered a new battery.
Is there anything I'm forgetting?
HP ze4365us, win xp home.
Thanks in advance,
Ken
  • kenp56 Nov 17, 2008
    I jsut reseated the ram, reseated the hard drive, and removed the wifi card. Still the same. The battery will not charge, the computer will not start on battery only nor starrt on power adapter either, so it is more than just a battery i agree. The new battery will not arrive for 2 to 3 days anyway.
    Thanks for the help, Thanks.
    Ken
    Sergeant:
    Champion:
  • 274 Answers
This may be an over heating issue. Blow out the air vents or open case and clean inside. Make sure cooling fan is spinning, if unit is warm.
Posted on Nov 17, 2008
  • 458 Answers
Are you sure it's the correct RAM?? Is it the Original Memory that came in the Laptop???
It Attempts to power on ???? Do you see Lights and does the fan Spin???? Does it get past POST?
  • 458 Answers
You just Replaced 2 things that have nothing to do with your Issue...
You Need to check your RAM and Hard Drive....Reseat Your Ram and test it
Also Make Sure Your Hard Drive is correctly in its slot..
That Make / Model is known for having a Faulty Nvidia CHip... Which causes that rebooting... Not Sure If THats Whats Happening with yours.. But Look Into It... They Are Repairing These Boards due to Recalled Chips...
Try Removing Your WiFi Card and Your Hard Drive....Remove Your Battery as well.... Plug In AC Adapter and try to power on the laptop.....
Solid amber light on GX270 no boot up
It's probably the memory or video card that is causing the problem.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 02, 2012 | Dell Optiplex 755 Small Form Factor...
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
I put my acer aspire in sleep mode and now it doesnt turn on
Hi marvmom,
Have you tried draining the power of your computer? The easiest way to resolve this issue is by performing a power drain. Please follow the steps below.
1. Turn of your computer completely by pressing the power button for about 10 seconds.
2. Now, unplug the AC adapter from the power outlet.
3. Remove the battery from the system.
4. Press the power button for at least 15-20 seconds.
5. Put the battery back inside the system and plug the AC adapter.
6. Try to reboot and observe the computer.
Hope it helps.
Thank you for using FixYa.
May 11, 2011 | Acer Aspire One PC Notebook
My HP 6720 won't switch on. When connected to the power source, a steady blue light comes on (normal) then goes to a light blue then goes blank. If I press the 'on' button, a flashing orange light appears...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 19, 2010 | HP Computers & Internet
My hp pavilion entertainment pc has power but nothing showing on the screen , plus when the pc is first turned on the fan comes on for a few seconds then goes off again . I've tried turning it off and...
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Sep 12, 2010 | Computers & Internet
I have a sony laptop vpcef2e1e .on pressing the start button it lights up green then goes of.have to do this between 5 or 6 times to get the computer to work.the computer is only 4 weeks old.
Sep 12, 2010 | Sony Computers & Internet
I have a toshiba m3 laptop, it was going then it froze, so i turned it off, now it wont start up, ac power and the on LEDs light up, if i remove and replace the battery the battery light goes momentarily...
4. The motherboard could be defective & needs to be replaced
Sep 10, 2010 | Toshiba Tecra M3 Notebook
Unable to start the computer. power button will light up for a second but no fans or other noises and then the light goes off
i would say try replacing the battery or the ac adapter. I had the same exact problem on my toshiba a105-s171. my battery was dead because the ac adapter failed to charge. Replaced the adapter and it works now.
Jan 18, 2010 | Toshiba Satellite A135-S4527 Notebook
When adapter plugged in computer starts then goes
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | Dell Inspiron 6000 Notebook
Tv will not turn on
Get a power extension cord to connect your TV power to another (zone)room by using a different outlet and see if that is still does it.
Remember when you unplug the TV,you want to give it 15-20 seconds first .
If it still have the same issue,i hope you have the warranty,you are going to need it for repair.
solutiondoct
Nov 11, 2008 | Hisense Televison & Video
HP Pavilion ze4365us Notebook Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
