Question about Dell Dimension 8300 PC Desktop
MY MONITOR HAS LOST COLOR.
THE COLOR HAS GONE TO GREYISH, AND THE IMAGES HAVE LOST SHAPE. PLEASE HELP!
    Scholar:
  • 57 Answers
Sometimes a loose cable will cause this issue. Check to make sure the cable to the monitor is not loose. The images loosing shape may mean there's an entirely different issue, though. I'm not a monitor expert, so not sure where else to proceed.
Posted on Dec 22, 2008
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
Monitor lost color went blue contrast. now well not turn on.
The monitor has at least two issues, the color is lost and gone to blue screen, second it will not turn on. It will be cheaper to replace the monitor with a new one rather than fixing the Star Logic Monitor. But I would suggest using a spare monitor to check the computer for any possible issue.
Jan 08, 2011 | Star Logic 17" LCD Monitor
I have a SAMSUNG SyncMaster 940bw about 4 years old which is on about 20 hours a day. A one inch grey stripe appears on the left side of the monitor running from top to bottom. Words and images on the...
Monitor this old will more likely to have bad DC filter caps by now, but you also may have failing LCD panel also. I would inspect the caps and voltages in the power supply section first.
You can failed SAMSUNG monitors due to bad caps in my albums.
You should read my guides also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 06, 2011 | Samsung SyncMaster 940N Flat panel Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Grey smudge like images on the screen.
Most possibly those are dead pixels. Those cannot be fixed in most cases. some software and some technic may help but that is not a confirm solution. please take it to the service center or talk them if still the warranty is valid and it covers the facts of dead pixels till date.
Apr 18, 2009 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
LCD lost the red color
First, plug a external monitor and toggle the screen with ALT+F4 to see if the image is correct there. This will discard software or configuration problems.
If the image in the external monitor is OK you problably have a hardware problem in the LCD panel or its cabling.
You can get the replacement parts here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
May 13, 2008 | Toshiba Satellite A75-S231 Notebook
DV-10 lost Color
It sounds like the color wheel broke, If you are good and experienced with electronics and can handle them safely, then open it up and check this part. This part spins and is the one in charge of producing the colors for the image.
Please let me know if you need any further help or have questions about this.
Thanks
May 03, 2008 | Optoma MovieTime DV10 Multimedia Projector
PRINTER COLOR
there should be some quality settings in driver menu or status monitor, check these.
Feb 06, 2008 | Minolta magicolor 2300W Laser Printer
Philips monitor problem
Check that the pc to monitor vga lead is not loose at both ends, check your graphics drivers are upto date, although it could well be a monitor fault and replacment required, as don't think they are worth reparing these days
Nov 02, 2006 | Philips Business 104B Monitor
Dell Dimension 8300 PC Desktop Logo
73 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
