Question about Kenmore Elite 45986 Front Load Washer
Thank you! Your suggestion on how to fix the F-DL clicking problem with the Kenmore washer totally worked. I tried it a year ago and it fixed the problem. It just started up again and so I did exactly as you suggested and it's up and running again. Can't tell you how thankful I am for your help! I would love a copy of the service manual if you still have it. Can you pdf it to my email? Jbdirkse@juno.com Thanks! Betsey Dirkse
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Posted on Sep 16, 2010
My kenmore e-4 front loader is not starting. It makes the clicking noise but then flashes f then dL. How do I fix this?
'dl' stands for 'Door Lock' and 'f' for fault. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
I bought this washer 5 years ago and it did not come with a book. It is now displaying LOC when I try and start it!! How can this be fixed????
"LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. This will fix the issue.
Thank you !!
Aug 16, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
F dL code message
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replace the door lock mechanism asap. this will fix the issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
Our Kenmore front loading washing machine HE3t has never had a problem until this morning. We tried to start a load and the machine is showing an error message ''dL'' followed by an ''F''. In the booklet,...
i replaced to door lock, and while I was at it the hinges and door lock latch.
this solved the problem. i found it had worked loose by leaning on the door.
you can find the parts at various vendors on the internet if you are handy to replace them yourselves. or call in a tech. i think the parts were under a $100 in total.
Apr 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer f11 f14 and dl codes
Replace the CCU it is your only choice. They do not make bandaids for washing machines. If you dont fix it you will just have a non working machine soon
Mar 31, 2009 | Kenmore Washing Machines
Kenmore elite washer oasis he, mod 110.27062603
to andreya ,,, the code dl means door latch ,,,, you door latch is bad on your machine
to afinebalance ,,,, the f1 code is the control board and it too is going out and it isnt cheap ,,,,
if ya'll want to send me your complete model and serial numbers i will check on the parts for both or you.
Larry
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Error F dL?
remove the top cover of washer at rear is the main control bd try wiggling the wires on front side usuually the larger wires if it works bad connections on control no fix but to replace it ..HOWEVER try shimming the plugs in place to hold them in position where it will work...possible door lock itself but control more likely
Sep 06, 2008 | Kenmore 46462 Front Load Washer
Kenmore elite he 4t washer
I have the he4t and everytime I wash I get an f02 error. The washer wont drain and spin unless you cancel and restart the washer. What can I do to fix this?
Feb 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Extra Heavy Duty Calypso Top Load Washing Machine
I had this problem and did not have the time to fix it myself so I called Sears. The "tech" looked at his laptop, called his "supervisor" a couple of times and told my wife that both control boards needed replaced at a cost of over $500. The manuals, with testing procedures for the inclined, are on the inside, front cover.
The CE error is a communications failure and on mine it required replacement of the AVS board. I bought the part at a local supply house and replaced it myself for about $175.
Jan 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore HE3t DL code
My husband and I had this same problem, but after visiting this website and reading through some of th posted solutions, we were able to fix our problem. Our 3-year-old Kenmore Elite H3 would not start on any cycle. It kept flashing the error code "dL/F", which we found out means "door lock failure." Taking advice, we unplugged our machine, removed the top panel, and rechecked the wiring. It worked! We think the wiring may have become loosened over time due to the jiggling vibration of our machine. Hope this helps you!
Oct 14, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
37 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
