Question about Sewing Machines
Singer Athena Rubber Washer replacement
Hi, my Athena just dropped several dried, hardened pieces of a rubber washer onto my hand. They fell out of the opening where the work light is. Any way I can get into the machine to replace this washer myself? This may explain the noise it is making. Thanks.
  • 27 Answers
This is a shaft washer designed to cushion the left right movement of the main shaft Lift the right side of the black top and slide it to the right and it will come off.
If you look closeley you will see a collar on the main shaft with 2 set screws ,this washer goes between the collar and the machine side . We use a delrin washer and cut out app 30degrees of this washer which will allow you to snap it over the shaft ,I hope this helps these were great machines
Posted on Jan 10, 2009
My thread will not turn to fill my bobbin. The motor runs but nothing turns. It has been slow for a few years, but now will not turn at all . The machine is a retro Singer Genie.
Hi either the bobbin is not locking onto the spindle or the rubber wheel inside has not enough tension or has been oiled incorrectly, if you push the bobbin holder spindle towards the hand wheel you should not be able to turn with your fingers.
Sep 22, 2017 | Singer Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
Thread breaking
Can you please tell me what is the model no. and the brand so that i can help you fix the problem.
Waiting for your reply..
Feb 24, 2008 | Singer CE-200 Quantum Futura Computerized...
I have an old wizard citation.. it was working great and then it stopped sewing and just makes a noise, but it still works manually.
If it's an old mechanical machine, it has probably seized from old, dried oil that acts like glue on the moving parts. Get some liquid Tri-Flow Synthetic Lube and, while manually moving the handwheel, apply a couple drops every place that metal rubs metal. Do NOT oil belts, rubber, or synthetic parts. Then apply hot air from a handheld hairdryer into the internal mechanics. You may need to repeat the process several times before it moves freely.
Nov 02, 2016 | Sewing Machines
How can I tell what year or model a Singer is?
Hi Donna,here's a link to your Singer,just enter your serial number to find out what year model it is. Singer Sewing Machine Company Serial Numbers
Sep 29, 2016 | Singer Sewing Machines
How to replace motor belt on singer 2ooo atens
I think you're referring to the Singer Athena 2000, a slant needle, touch and sew machine.
I don't have a service manual for that machine, but on all the machines that I have worked on, there are two belts near the hand wheel, and the tensioner is at the center--the part where both belts come together--and you can adjust it by loosening two Phillips screws.
However, before you attempt something like that, you will need the parts number, and I would purchase the service manual. You can get a part list free and purchase the service manual here. Singer Athena and Touch Tronic
Apr 07, 2015 | Singer Sewing Machines
How do I replace the drive belt on a Singer Athena 2000?
Generally, the hand wheels have a screw at the center that is covered by a white disk. You use a flat bladed screwdriver to "pop" the disk off, and the screw is underneath. If there is no screw, then it's a "force fit" and you remove it by squeezing the wheel together and "rocking" it off.
Oct 18, 2014 | Singer Sewing Machines
Bobbin winder "washer"
It's called the
"bobbin winder friction ring"
You can find one on the site below for $1.50 or so.
https://www.vintagesingersewing.com/catalog/index.php?cPath=42&osCsid=7697cebcf0714ac3da8b2c1101c98365
It's the last listing for machine parts.
Hope this helps, please rate this if helpful
thanks
moni
Sep 15, 2009 | Singer 5050 Mechanical Sewing Machine
Singer Athena automatic needle threader does not work.
Check on the threader and see if the part that goes through the eye of the needle is bent. This is a very common problem. The threaders are becoming more and more difficult to replace. If the piece is bent, you can usually use a pair of tweezers to straighten it out.
Feb 07, 2009 | Singer 132QRFB Mechanical Sewing Machine
Problem with winding thread onto the bobbin (small free- arm Singer 100 sewing machine). Once bobbin winder shaft is pushed to the right nothing happens-bobbin rod does not start turning so I cannot wind...
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Aug 18, 2008 | Singer Featherweight 140Q
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
