NEC PlasmaSync 50MP1 50 in. Television
Problem for NEC PlasmaSync 50MP1 50 in. Television
Monitor goes black - green light stays on
By fafisi on Dec 17, 2006
The picture is perfect when the screen is on, but it goes black very shortly after startup, and sometimes goes back on and off in no apparent pattern. Sometimes I can manipulate it back on for good by turning the system on and off a few times but it is very unreliable. Any clue as to why this occurs and how it may be fixed??
Same Problem
Nov 01, 2008
-   picture goes black -   Guest
Sep 03, 2008
-   I have 4 of the xp17w and they all have the exact same problem. : (
Nothing seems to help.
-   scrutor
Aug 17, 2008
-   Have the Sharp LC-32D41U, 1-1/2 years old, kept losing picture and sound, turned set off and then on again, would immediately lose both picture and sound again. Authorized Service Center (out of warranty, of course) said it needed RDENCA161WJQZ (Power CBA) and also
DUNTKD640FM22 (Main CBA); parts/labor $799; TV bought from HSN for $999. TV will now collect dust in basement. Seems as if we are a true throw-away society.-   gatorrx
Aug 11, 2008
-   Our TV is almost 8 yrs old. Recently the picture started to go off intermittently to a solid grey screen with pink/red lines. Recently we dont even get that - it goes to solid black. We have to turn the screen button off (volume still on) and leave it off for 10 - 20 minutes and then turn it back on and it will work for a few more hours. We have a PRO 710HD Elite.-   kikocat001
Aug 02, 2008
-   Turn the tv on it will flash digital tv for about 10 -15 seconds and then the green light will turn off and go on stand by mode-   zkannapel
Best Solution
posted on Jul 19, 2008
Very Helpful)
lfostano
Rank: Apprentice
Rating: 100%, 2 votes
Could be the back light is not working properly, some have a balance circuit that needs to see the upper and lower back light on and if one is not working it shuts down .Also some models are wired through the processor , you cna change out the processor or hard wire around the processor the back light.The back light will come on only when powere is cycled and should work for you just fine and is the cheapest method.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 18, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had this TV and had the very same problem.  It's the power board and circuit board combination.  I had it under warranty still and they contracted an A/V tech to look it over.  It's been 5 months and I'm considering a lawsuit in order to get my money back.  Hope you have better luck - but that is the problem!
Solution #3
posted on Feb 12, 2007
Very Helpful)
JoeO700
Rank: Guru
Rating: 90%, 170 votes
We have seen connection problems on the Y-Sustain board causing this problem. Connections breakdown due to the high heat and frequency of operation on this board. Have a qualified service tech. inspect the board, if damaged, it is best replaced to assure a quality repair. Be sure to ventilate this set properly, overheating leads to 80% of all failures in these sets.
Joe Weibel
Was this helpful?
Yes
No
Solution #4
posted on Jan 19, 2007
Very Helpful)
jmitsoulis
Rank: Guide
Rating: 89%, 10 votes
Replace X-Y sustain boards
Was this helpful?
Yes
No
Solution #5
posted on Jul 06, 2007
Very Helpful)
scientist
Rank: Apprentice
Rating: 95%, 4 votes
the fact that the green light is on means that the correct video signall is being recieved,there fore the back light invertor could be at fault.
try to see if you can faintly see the picture during the aforementioned fault condition....if you can ,then the invertor is the problem .this isnot a hard fault to repair as it is only a high voltage ac powersupply...colin campbell
Was this helpful?
Yes
No
Solution #6
posted on Jul 24, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Good tip henlopen,
I have a similar problem. I got the TV from my uncle who claimed the problem is intermittent.
All I observe is that when I plug it (Insignia HDTV32 inch), the Led shows red and then when I press power it goes blue, tries to turn on the screen, the screen backlight comes on for a half second then it goes off and the LED goes off and comes back on as red a moment later. A crack is heard from the speakers when this happens.
After that pressing the power again causes the LED to go off then come on as red again.
If I hold the power down, the speakers make a crack noise and the LED switches from blue to red constantly.
I'm thinking this is an internal power problem or something, but I'm not very experienced with circuitry repair, other AC to DC conversion circuits, which are mad simple.
Solution #7
posted on Jan 16, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This sounds like you have a bad 10mf caparcitor in your power supply have it checked out by qualified tv tech.
Solution #8
posted on Jan 12, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same problem as mine. Best way to fix this problem is to send in your tv for a warranty repair ASAP. If you don't, your tv will go black permenantly.
Solution #9
posted on Feb 02, 2007
Helpful)
imarebl
Rank: Apprentice
Rating: 89%, 12 votes
I was having the same problem with my Pioneer plasma PDP-4340HD (randomly shutting off and after a few minutes I could turn it back on w/ the remote) then, one time, rather than shutting off it flashed the red and green boxes. I replaced the system cables and now it won't even power up. I also get a (red) flashing stand-by light on the media receiver and if I push the on/off button on the remote or the display panel the (orange) recording timer light will flash for 10 or 15 seconds and then quit. Still no power. Any solutions?
Was this helpful?
Yes
No
Solution #10
posted on Jan 08, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
update your chipset drivers
Solution #11
posted on Aug 16, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a TV repair friend that sees this issue all the time. The cheap buggers pur 3rd grade Caps in the power supplies (could be as many as 30) made in China that don't work worth a damn and could pop in the slightest amount of excessive heat. Oh-yeah, the Plasma's make lots of heat and have poor ventilation.
Fix: Replair all the caps in the power supply with good quality ones and your good to go.
Solution #12
posted on Jan 02, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
What worked for me was unplugging the back plug and plugging it back in. Worked like a charm.
Solution #13
posted on Dec 24, 2006
Somewhat Helpful)
henlopen
Rank: Wiz
Rating: 84%, 650 votes
It sounds like a bad connection, solder or otherwise. You can probably get the symptoms to come and go by lightly tapping the monitor cabinet. Don't continue to do it though, it may make it worse over time. A competent repair shop should be able to handle this type of repair.
Was this helpful?
Yes
No
Solution #14
posted on Mar 02, 2008
Somewhat Helpful)
rugburner
Rank: Apprentice
Rating: 70%, 2 votes
every once i while half the screen turns pink and white, the bottom stays good, so far it has gone away, what do i do?
Was this helpful?
Yes
No
Solution #15
posted on Dec 14, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The backlight inverter is the cause of the blue screen flash and then the TV goes blank. There is a Yahoo Group that is dedicated to the problem. Some of the members of that group fixed the TV for $25 while others fixed it for less than $200. Olevia basically lied to the consumer when they said that the inverter was part of the LCD panel and the TV had to be returned for them to fix it. Olevia does not manufacture the inverter it is made by Darfon. However, Olevia could have offered a redesigned circuit board at a reasonable price and made a whole group of consumers happy that their investment was a good one. They chose not to and that will hurt their reputation.
Solution #16
posted on Nov 01, 2008
Very Helpful)
acarroll110
Rank: Apprentice
Rating: 100%, 1 votes
I have a Hitachi plasma, 42 inch TV. Its about 2 years old. Anyway when we tried to turn it on, the screen would come on for a few seconds, then it would go black and the power light would flash. The sound still worked fine. Anyway I opened up the back and noticed one of the two cooling fans was not working.
I ordered a replacement fan online using the same model number of the fan in the TV and now the TV works fine. A serviceman I spoke to said that its a safety feature to stop the TV from overheating. If one of the fans is out, it goes into safe mode. Hope this helps. Taking the back off the TV is pretty easy. The fans are easy to remove too. Something to look into. I figured if the picture was clear for a few seconds that it couldn't be something major with the X or Z boards.
Was this helpful?
Yes
No
Solution #17
posted on Sep 20, 2008
Not Rated)
rbigdoe
Rank: Apprentice
Rating: 0%, 0 votes
monitor is black and no signl
Was this helpful?
Yes
No
Solution #18
posted on Jul 01, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My 19" Dynex all of a sudden has no sound and no picture, however the little green light is on, checked all plugs they are ok, what is going on with these 19" Dynex tv's???????? barbl@jarodo.com
Solution #19
posted on Jun 12, 2008
Not Rated)
mick TV
Rank: Apprentice
Rating: 0%, 0 votes
Its the inverter panel
Was this helpful?
Yes
No
Solution #20
posted on May 06, 2008
Not Rated)
myria
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem it get disoriented and I have shut the tv off and on but it jumps and turns green and red. I contacted customer service and they will not return my phone call. I purchased this tv 2 months ago.
Was this helpful?
Yes
No
Solution #21
posted on Mar 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I believe it is an over heating problem and a bad component short
Solution #22
posted on Feb 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
having the same problem here mates >_<
Solution #23
posted on Oct 02, 2007
Not Rated)
Rhome
Rank: Apprentice
Rating: 0%, 0 votes
I HAVE THE SAME PROBLEM WITH MY LG RU-42PX11. AFTER ABOUT 25 MINUTES MY PICTURE WOULD BLINK TO A BLACK SCREEN AT RAMDOM. TV TECH TOLD ME IT WAS THE UPPER & LOWER CIRCUIT BOARDS $265.OO PARTS ONLY. SO I ORDERED & CHANGED NOW IT PLAYS FOR TWO HOUR THEN BLINKS. SO NOW I CALL A TECH FROM CIRCUIT CITY $99 TO CHECK PROBLEM WHICH GOES TOWARD SERVICE & PARTS IF YOU GET IT DONE. THE LG SERVICE SHOP WERE I ORDERED THE UPPER & LOWER CIRCUIT BOARDS TOLD ME TO ALSO CHANGE THE MAIN "Y" CIRCUIT BOARD THE UPPER & LOWER CONNECT INTO A $280 PART, BUT MORE DIFFICULT TO REPLACE BY MYSELF. SO IF CIRCUIT CITY HAS A GOOD PRICE I WILL GIVE THE TV TO MY MOM. JUST PAID FOR A SONY BRIVIA 46 INCH 3YEAR EXSTINED WARRENTLY THIS TIME, WITH OPTION TO RENEW!
Was this helpful?
Yes
No
Solution #24
posted on May 07, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
NEW POWER SUPPLY. LOOK OUT FOR THE REPAIR COST. HAVE BEEN QUOTED OVER >$1,000 WHEN POWER SUPPLY IS SUB $500.
Solution #25
posted on Apr 08, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
do not get mad and spank the back to hard this may ground-out the main power and blow the fuse.
Solution #26
posted on Feb 03, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It's the scaler board according to my tech. The replacement board is no longer manufactured.
Mine has the same symptoms but the light alternates rad and green.
Solution #27
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This is component level failure - probably a filter capacitor.
Solution #28
posted on Jan 29, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
change y sustain board or might also need z sustain board form LG
Solution #29
Not Rated)
xboxfreak
Rank: Apprentice
Rating: 0%, 0 votes
I have the same PDP-4330HD and have the same problem. It started several months ago very intermittently. The frequency increased until it is every 5-10 minutes. Real pain! In desperation, I removed all the cables from the monitor and the receiver, opened up the receiver and gently pushed the capacitors and other components looking for something loose. After I put everything back together again, the set worked perfectly for 8 days...then the same symptoms reappeared. Hard to believe that the connections have loosened again, so it must be some component on one of the boards in the receiver. I am at my wits end. I can only envision the troubles of finding a competent, honest repair shop!
Was this helpful?
Yes
No
Solution #30
posted on Jan 15, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
possibly a bad inverter. I found this web site.
http://www.lcdpart.com/Products/t5010450...
Sounds like your problem.
Popular Solutions for NEC PlasmaSync 50MP1 50 in.
Questions and Unsolved Problems for NEC PlasmaSync 50MP1 50 in.
Do you recommend NEC PlasmaSync 50MP1 50 in. Television?
Answer
Answer
My LCD TV picture goes black when the thermostat clicks on, or someone turns the ceiling fan off?... (More)
Answer
ok my computer screen is green and i need it fixed, how do i do it?
Answer
Brand new Panasonic Plasma....screen goes blank intermittently...can happen 3 to 4 times per hour... (More)
Answer
I bought a philips lcd tv a few days ago. The model is 32pfl5624. When i plug it to ps3 everything... (More)
Answer
The picture is perfect when the screen is on, but it goes black very shortly after startup, and... (More)
39 Other Users Have The Same Problem - Continued
Comment by PIENAARDIRK, posted on Jul 21, 2008
the monitor keeps on going black, red light flashes a few times and tv switch off, this is a brand new tv. 2 months old. is it a setting or a fault with tv. please help if anyone knows....will apprciate it a lot!! dirk
Comment by Guest, posted on Jul 21, 2008
Comment by 2135, posted on Jul 14, 2008
monitor when black while i was watching a movie. Sound was still working. Now the screen flashes when I turn it on, but immediately goes black and then I loose the green live.
Comment by Guest, posted on Jun 22, 2008
Comment by Guest, posted on Jun 08, 2008
My plasma TV 50 inch screen goes Green when I turn on and does not show the normal picture. it stays green
Satish.jindal@gmail.com
Comment by Billybob1957, posted on May 28, 2008
Monitor goes black -volume stays on and green light stays on problem, and notify you when a new solution is offered.
Comment by guest5, posted on May 27, 2008
We have the same issue. Black screen with sound. The picture will come back on periodically but alas goes black again. Has anyone had luck getting theirs repaired?
Comment by katana62678, posted on May 22, 2008
I have the same problem, the TV is plugged in, when the power button is pressed, the green light comes on, but there is no picture, regardless of what buttons I push on the remote or on the tv itself. Was there ever a resolution for this or what part(s) needed to be replaced?
Comment by Guest, posted on Apr 29, 2008
yeh it shows a little white then boom! black with green light on!
Comment by Guest, posted on Apr 27, 2008
I need to turn the tv on several times in order for it to remain 'on'. I'm able to keep the picture on if I turn the OPC off and set the brightness to low.
Comment by Guest, posted on Mar 19, 2008
i have an nec 42mp3 and it does the same thing.
it seems like the longer it's unplugged, the longer it will stay on when it's plugged back in. the screen will go on and off when it wants, though.
Powering on and off a few tiems usually fixes it. Picture is perfect when it's on, though.
after being unplugged a while, the screen fires up with random red static then settles down. minutes or hours later, the screen will kick on.
weird.
Comment by jay9ny, posted on Mar 09, 2008
** Picture but I get sound. Told I need all of the boards replaced but that it costs more than the tv new. Any suggestions on where to find replacement boards to diy.
Comment by pansey21, posted on Mar 03, 2008
I just got this product, plugged it in and i have audio but no video. the green light is on but the screen is black. what can i do or what do i need to do?
Comment by Guest, posted on Mar 01, 2008
screen goes black and red light flashes 4 times and pauses as a pattern what has happened
Comment by Guest, posted on Feb 26, 2008
have sound no pix blue sceen back to black whit sound
Comment by scouse270162, posted on Feb 21, 2008
got a philips 26pfl5522d/05 screen lights up on switch on then goes of with blue light stays on
Comment by Guest, posted on Feb 15, 2008
the screen is black but the green button turn on and off continusily. help!!!
Comment by Umodzi, posted on Feb 13, 2008
The LCD TV is new but when you switch it on the LCD just blinks i.e. it comes on then off.
Comment by Marco6321, posted on Feb 10, 2008
Monitor want black - green light stays on problem
Tried all other video ports same result. New unit only 2 months old
Comment by wunjo, posted on Jan 15, 2008
When HDMI (PC DVI to HDMI) has a connection, the TV will not turn on when the power button is pressed (either from remote or TV).
The green light becomes activated, but that's it. Any attempts to turn off the TV, change the channel, input, etc, all fail. I have to unplug the TV and plug it back in to "reset" whatever problem is.
Any Ideas? RMA time?
Comment by Applesnacks, posted on Jan 01, 2008
When i turn on my computer it goes black after like 2 seconds. I can always turn the monitor off and on again but it goes black again. (It is my monitor because i checked it by conecting it to my second computer)
Comment by BWMoore, posted on Dec 29, 2007
My Toshiba 42HL67 is two days out of the box. Suddenly we lost all video in the middle of a PS3 game. The sound is still present and the green light stays on. I've read the entire manual including the troubleshooting section, which does not address this problem. I've tried pushing all the buttons on the remote, but with a black screen it's useless. I'm waiting for my sales rep from the local TV store to call me back with a solution, I hope.
Comment by Vanoie, posted on Dec 28, 2007
I have mine connected to a computerit worked fine. One morning turn it on and no picture. I thought it may have just over heated? But still have the same problem. I did get picture back for a few minutes.
Comment by Guest, posted on Dec 27, 2007
THE PICTURE COMES ON FOR A FEW MINUTES, THEN GOES BLANK BUT THE POWER LEAD STAYS GREEN/ON
Comment by Guest, posted on Dec 13, 2007
I have a 42 inch LG lcd I just bought about 3 months ago starts off working screen goes out you have sound, comes back on goes in and out then eventually sound goes out and then the tv wont turn on you have to wait a while turn it on and it works. Other times it works with no problems
Comment by Guest, posted on Dec 06, 2007
mine just goes black and the sound stays on whats the fix?
Comment by caitstern, posted on Nov 30, 2007
same exact thing on an ns-lcd 22
Comment by Guest, posted on Nov 27, 2007
My problem with the Sharp Aquos is it goes black after a cople of minutes, we put a fan on it to cool it down and it does seem to work better, but it still turns off.After reading the same problem with other people, I would suggest avoiding Sharp televisions and buying something else with a long term warrenty.
Comment by Guest, posted on Nov 24, 2007
I have the same problem. Tv starts up go black within 20 minutes green light still on. If I shut it off for a period time say 20 minutes the screen goes back on. The problem then repeats itself. Took to a recommended sharp repair center . They quoted me 800 dollars for a new lcd panel . The tv is only 15 months old. It's my first Sharp and probably my last. 20in aquos sharp tv brought july of 2006. If anyone has any other ideas let me know.
Comment by Guest, posted on Nov 22, 2007
Comment by jem4693, posted on Nov 21, 2007
I have a audiovox FPE3206 lcd color flat panel tv. My wife was watching the other day and it just went black. I called my cable company and they had me reboot the cable box, but nothing happened. When I turn the TV on, it usually shows AUDIOVOX on the bottom of the TV before the picture comes on. Now, when I turn the TV on only the blue line comes on and nothing else. Can you tell me wht the problem is. I've only had this TV for about 7 or 8 months. My e-mail address is MYTHAI51@MSN.COM Thank you
Comment by fume, posted on Nov 20, 2007
same exact problem here ( as fafsi), will any advice at this time ..Thankz
Comment by pizzaman1, posted on Nov 08, 2007
I was watching my tv and it just went off. i also have dish sat. tv on it. the blue light comes on for about 2 seconds like it' s going to come on but then it goes out. after that the red light flashes on the botton left corner. i have unplug the as well as turned the power off and on but this does nothing. What can i do?
Comment by Sultani, posted on Nov 08, 2007
When I turn on my LC-37P50E four columns (each about 4") with green color appear in black backgound in the right side of LCD.
When I watch tv black things on this four columns are seen in green. what should i do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , DC
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
