Question about Lexmark Office Equipment & Supplies
I do not know how to replace an ink cartridge in a X3 printer.
  • 749 Answers
Http://support.lexmark.com/perl/support/support.cgi <--complete instructions
This document does not apply directly to your Lexmark X3580
To install a cartridge using the Solution Center:
  1. Make sure the printer is switched on, the old cartridges are still in the printer, and the cartridge cover is closed.
  2. Click on Start, Programs (XP: All Programs), Lexmark <Printer Name>, Lexmark <Printer Name> Solution Center.
  3. When the Solution Center screen appears, click on the Maintenance button on the left-hand side. (This button is the third from the top and bears a picture of ink drops.)
  4. When you see the Install or obtain a New Cartridge option, click on it once. A pop-up displays a brief description of how to physically remove an old cartridge and install a new one.
  5. Follow these instructions and click Next. The software will prompt you to confirm whether the cartridges are new or old.
  6. For the new cartridge you just inserted, select No, it's new. Important: Make sure the setting for any old cartridge stays on Yes, It is old.
  7. Once your selections have been made, click OK. The program will want to run the alignment for any new cartridges you installed. This applies whether you changed one or both cartridges (in the case of printers that can hold two cartridges). An alignment screen with a red and white bull's eye will appear.
  8. Make sure the cartridge cover is closed and that there is paper in the printer.
  9. Then click the Print button on the alignment screen. A sheet of paper will print from your printer with a series of arrows and numbers on it, with one set of solid bars above them. You should see four groups of lines, unless you have a single cartridge. If you have a single cartridge, you will only have one set of lines.
  10. In each group, locate the arrow that looks the most solid. It may help to circle the number under each arrow you choose as you go along.
  11. On your screen, you will see an area where you can enter the alignment values. When you have identified all the numbers, select those same numbers for each group on your screen, using the up and down arrows next to each value for A, B, C, and D (or A if you have only one cartridge).
  12. When all the numbers have been changed to reflect the chosen numbers on the printed alignment page, click OK. The cartridge installation procedure is complete.
  13. You can now exit from the Solution Center
Posted on Nov 17, 2008
  • Lexmark Master
  • 1,879 Answers
You can also use the utility in the computer to change the cartridge.
  • Lexmark Master
  • 19,396 Answers
Pull up the cover. The carriage will move to the center pull the cartridge toward yourself and extract it , insert new cartridge in same way, I will give you the pictures.
Basti
  • 1447 Answers
SOURCE: Code:P error message: Pad saturated.. ink leaked..replace cartridge
Hi!!
Chances are the printer needs maintenance, you can actually send it to a repair center to replace the inkpads for your printer, try this link for information and you can download as well the utility from this site after registering:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Your printer has a one year warranty if its still within the warranty call epson if not try this site www.epson.com/loyalty and try the passcode minute or market and register. Hope this help. pls dont forget to rate solution. Thanks!!
Posted on Apr 19, 2008
professor_sc
  • 180 Answers
SOURCE: Refilled ink cartridges
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
Posted on Aug 04, 2008
SOURCE: lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
Posted on May 21, 2009
benwabnick
  • 2404 Answers
SOURCE: how do i change ink cartridge 21 in hp deskjet D1460 printer
Here is the manual for your printer courtesy of HP:
http://h10032.www1.hp.com/ctg/Manual/c00905267.pdf
On page 47 of the manual it explains how to change out the cartridges.
Let me know if you need more help.
Posted on May 23, 2009
  • 7 Answers
SOURCE: replacement of ink
Hi,just go to the printers properties select maintainance select status monitor from there the procedure is self explanatory,try that.
Posted on Jul 01, 2009
How do I resolve ink system failure 0xc18a0306?
When powered up press the ink button. This should cause the print head to move to the middle the printer and then back. If it parks properly then everything should be fine. However, if it stops against an ink cartridge it's indicating a problem (no ink/ faulty cartridge). So replace it and repeat the process x3 (ie.for the 3 other cartridges). Once complete the printer should be OK. All this should be covered in the HP user manual.
HP Official Site Laptop Computers Desktops Printers Servers Services and...
Aug 08, 2015 | HP Photosmart C8180 All-in-One InkJet...
On HP Photosmart 7960, which cartridge to replace when the blue and green look pale
The printer takes a tri-color cartridge and a black cartridge. So anytime there is an issue with color, replace the tri-color cartridge. As far as using compatible inks, you will not be able to use HP's software for ink levels with compatible inks. This feature will work only with HP ink cartridges.
Oct 23, 2011 | HP PhotoSmart 7350 InkJet Printer
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
Printer doesn't revognize new ink cartridge
Are you using Dell Series 5 ink cartridges? Dell Series 5 ink cartridges have a cartridge that cannot be reset.
Article on refilling Dell ink cartridges
It's possible to get a bad Dell Series 5 ink cartridge. Return to place of purchase for a replacement.
Rick
May 24, 2010 | Dell 924 All-in-One InkJet Printer
How to change ink
Hi there
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Epson-Stylus C86-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 14, 2010 | Epson Stylus C86 InkJet Printer
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Refill cartrige and printer says replace cartrige
A lot of printer manufactures place a small chip on the ink cartridge. Combined with the printer software it knows you re-filled the cartridge. This forces you to buy new ink. A work around that works with some printers. Keep you're old ink cartridges. Replace with new and when it empties replace with you're re-filled ink cartridge. Store you're old re-filled cartridges in a dry cool place when not in use. With HP printers users keep three cartridges.
Good luck.
Mike
Jan 14, 2010 | Lexmark Z2420 Printer
Ink cartridge cannot be used after initialization
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Aug 04, 2008 | HP OfficeJet D125xi InkJet Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
