Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
A loudgrinding that sounds like gravel is in washing machine
The grinding noise is only in the rinse cycle. Can we take some thing out that would let us see if there are coins stuck somewhere?
  • 4 more comments
  • gnorga Nov 29, 2008
    Same thing, a grinding sound during the rinse AND spin cycles. Don't think it's a foreign object. Sounds like metal-on-metal.
  • Anonymous Dec 06, 2008
    cheap POS
  • karma52 Dec 07, 2008
    We have the same problem - took the pumps off and looked.  We can see it, just can't get to it.  If anyone has suggestions, please pass along.  Thanks.
  • Anonymous Jan 19, 2009
    Due to this problem I have had to replace the pump because the change
    punched a hole in the black chamber causing the washing machine to leak all over my floor. I replaced this piece in October and now will have to replace it again for the same problem. There is a defect in this pump housing that it could actually get a hole and cracks in it. The part was over $100.
  • Anonymous Feb 25, 2009
    i have this same washer and i have had the pump go out twice now and i have had a friend clean my pump 10 times i have had this washer for a year and a half this part is defective they need to build a filter or something to fix this. i have never had a washer that sucks change up. i have extenstive water damage to my floors
  • offedge Apr 02, 2009
    I have the same problem but the coins have not made it to the pump yet, how do you get the outer drum disassembled?
I have had this same problem, coins get in the discharge and recurculation pumps. Tip it on its front side remove pumps 3 screws each, unplug wires remove 4 phillips screws and remove black housing off pump and clean,reassemble. Don't forget to check outer drum for more coins.
Posted on Jan 18, 2009
  • 370 Answers
You will have to take the pumps off. Just take the back or front off to do it. you may have to lean the washer one way or another.
Posted on Nov 17, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have an haier washing machine that gets stuck at the rinse cycle. What could it be? Plus it makes loud grinding noise.
are u saying its putting water in the draining over an over? or not rinsing at all? if no water coming in check water inlet valve. if its draining over and over>? check ur drainage and water pump
Jun 15, 2015 | Haier Washing Machines
Fisher Paykel washer repair
it will be the pump. just check again where you did last time. there may be something in the hose, coins can get stuck, and lint. check also the pump is not getting very hot.
Aug 08, 2014 | Fisher and Paykel WA37T26G Top Load Washer
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Cotton program stuck on wash cycle with 1 minute left
Control board needs to be replaced. Many times the control boards go bad because of a spike in the electrical grid cause by a brown out, lightening strike or even a surge in the power. After the control board is replaced... I suggest using a surge protector on all of your electronic devices including the washing machine.
Feb 06, 2014 | Hotpoint Ultima WF865 Front Load Washer
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Maytag agitator will not turn
Sounds of a loose motor or need brushes replacement.
Jan 13, 2018 | Maytag MAV6457 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,468 people viewed this question
Dan Webster
Dan Webster
Sal De
